A friend of mine said i should get some aftermarket pulleys and after thinking about it i should. i know that Grand Prix's have 3800 Series II Engines. I dont know about the bolt-ons/internals of them. could i buy an aluminum flywheel, water pump, alternator pulley and is it worth buying. im tryin to shave a little weight, build my ride stronger and produce better revability of the motor. if this is something i can do, then what type of pulleys should i replace? what type should i get as well underdrive or overdrive?
Flywheel, pulley's etc...
My ride: <br /><a href=\"http://members.cardomain.com/youngdeezy\" target=\"_blank\">http://members.cardomain.com/youngdeezy</a><br />98 Firebird 3.8L A4<br />Mods:80 seires flow master muffler<br />dual exhaust 3\" pipes,whisper lid<br />k&N filter,3.42 gears and LSD, 180 thermostat, free ram air mod & 1/2\" raised air box + some apperance mods<br />1/4 mile 15.8 @ 85mph<p>I\'ll see you in the traffic...Tags: None
movign to general tech.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
The main pulley to get is an underdrive crankshaft. It'll be smaller then the stock crankshaft (and lighter), so it'll drive the accessories a little slower and give you a little more power. You could also get an underdrive alternator pulley if you want, but if you're running an aftermarket stereo or a lot of electrical stuff, I wouldn't suggest that unless you got a higher output alternator.
Chris<b>2002 BSM TransAm WS.6 M6</b><br /><b>350rwhp, 365rwtq</b><br /><b>Stock:</b>13.455 @ 105.39 2.129 60\'<br /><b>Mod:</b>12.449 @ 113 1.832 60\'<br /><br /><b>2004 QSM GTO M6</b><br /><b>303rwhp, 329rwtq</b><br />Stock: 13.74 @ 102.14 2.1 60\'<br /><br /> <a href=\"http://members.cardomain.com/silvertaws6\" target=\"_blank\">http://members.cardomain.com/silvertaws6</a> <br /><br /><b>1984 Firebird S/E M5</b><br />2.8L
Smaller on the crank, larger on everything else.
Talking 3.8's here:
There are not crank pullies available for us, seeing as we have a harmonic balancer / dampener / etc. on it at the moment. Maybe one day.
ZZP makes a WP pulley in underdrive form, and a Alt pulley in -10%, -20%, and +5%. I have the WP, and it was maybe a 1/2" in larger diameter, and lighter, though the weight removed was in the center (not very important for rotation). Either way, I've got it, I'm happy. I held off on the alt pulley.
As for the flywheel, I heard that someone (was it spec? or someone else?) had offered to a member to take about 20 lbs or so out of his flywheel for a few hundred bucks. Very decent idea, though I don't know what happened after that.
-Rob<b>97 Camaro 3.8L M5</b><br />Car for sale<a href=\"http://terpmotors.com\" target=\"_blank\">terpmotors.com</a> Terrapin Motorsports! UMCP
thanks for the info but im not to sure about this. for all of the lil work it'll be and paying for the pieces, i dont know if its really worth it.My ride: <br /><a href=\"http://members.cardomain.com/youngdeezy\" target=\"_blank\">http://members.cardomain.com/youngdeezy</a><br />98 Firebird 3.8L A4<br />Mods:80 seires flow master muffler<br />dual exhaust 3\" pipes,whisper lid<br />k&N filter,3.42 gears and LSD, 180 thermostat, free ram air mod & 1/2\" raised air box + some apperance mods<br />1/4 mile 15.8 @ 85mph<p>I\'ll see you in the traffic...
