The 5.3L Swap? - FirebirdV6.com/CamaroV6.com Message Board
The 5.3L Swap?
  • The 5.3L Swap?
    Hey guys i was just doing a bit of browsing around on LS1 Tech for engines, and it seems like you can pick up a 5.3L for fairly cheap, I know obviously you need a few more parts and cash besides the engine itself but has anyone swapped a 5.3L V8 into their car? sounds like it might be kinda unique
    Robby
    2001 Chevrolet Camaro 3.8 V6
    |JET Chip|Flowmaster American Thunder|K&N Intake|BMR STB|Spohn Rear Sway Bar|
    http://speed-bros.com/
    Re: The 5.3L Swap?
    not really unique anymore. lol. just go over to tech and there are threads in the conversion threads. been done quite a few times already
    http://www.bowtiev6.com/
      Re: The 5.3L Swap?
      assuming you are talking about an ls1 and not a 350sbc.. the general consensus its pretty much cheaper to either buy a donor car, or buy a wrecked z28 roller and put the engine in that car.
      things you would need:
      ecu/wiring harness
      fuel pump
      front springs
      k member
      trans xmember (maybe)
      driveshaft (if the car has a 2 piece)
      radiator
      engine/trans
      gauge cluster
      steering rack (although im sure you can use the old one)
      exhaust (downpipe may be slightly different)
      throttle cable/drive by wire (if you have a 98' and below camaro)
      im sure there is a few other things also that i have forgotten
        Re: The 5.3L Swap?
        don't forget a new rear end if it's stock
          Re: The 5.3L Swap?
          It would be cheaper to run a turbo with low boost and get 290-300 at the wheels , a 5.3 say a 2000 is rated at 275HP and 315 TQ then take 20% drivetrain loss its only making 240 HP / 265 TQ at the wheels , some have got those on #'s N/A on 3.8's. I think the LQ9 (I think) is the best option if your looking for a less inexpensive motor out of a truck to swap in for the best HP and TQ.
            Re: The 5.3L Swap?
            LQ9 > LQ4. otherwise you might as well just plan a ls1 swap. LQ9s make nice boost motors, ive been looking high and low locally for one for 5 or 6 months now.
            Follow me!
            Or this
              Re: The 5.3L Swap?
              ecu/wiring harness
              fuel pump
              front springs - Don't Need
              k member
              trans xmember (maybe) - Do need
              driveshaft (if the car has a 2 piece) - Only if it's 2 piece
              radiator - Don't need
              engine/trans
              gauge cluster - Dont need
              steering rack (although im sure you can use the old one) - Don't need
              exhaust (downpipe may be slightly different) - Do Need
              I went through and fixed your list
              If you have a G80 code rear, you can use your stocker. I'm using a stock V6 rear in my swapped car.
              5.3's are no slouch. Just like an LS1, very underrated from the factory. They typically dyno within 10-15 hp of a 5.7 LS1. You could do the 5.3 for FAR less than a turbo kit.
              LQ4/9's are going for bucks right now. You can find a 5.3 for $300, similar LQ4/9's are going for over $800. I keep saying it. www.car-parts.com junkyards post parts on there.
              As long as you have a 99+ car, the swap is SUPER easy. You need to jump 1 wire on the harness to make it run.
                Re: The 5.3L Swap?
                hell the cheapest i found locally was 1400 bucks lol. people around here think the damn things are gold plated or something. ill have to look thru there then. i cant do **** with this car until i pick one up.
                and agreed, the 5.3 is under rated. for all intents and purposes its just a baby ls1. although i seem to remember reading that the internals are a bit weak in them.
                Follow me!
                Or this
                  Re: The 5.3L Swap?
                  they have them for sale locally for usually under 500 for the engine, or entire drivetrain for less than 800. i bought a whole truck for cheap as hell cause i wanted to do this swap, but...well plans change.
                  Team NoVa
                    Re: The 5.3L Swap?
                    thats not a bad idea either now that i think about it.
                    Follow me!
                    Or this
                      Re: The 5.3L Swap?
                      the steering rack will not work, you can put av8 one on a v6, but not the other way around.
                      sure, you dont need to change the springs, but the front will sit down a lot lower
                        Re: The 5.3L Swap?
                        he just did a ls1 swap into a v6 car FYI
                        Follow me!
                        Or this
                          Re: The 5.3L Swap?
                          everything i looked up said you cannot use the v6 one because the k member gets in the way since the v6 one is larger.
                            Re: The 5.3L Swap?
                            If you have the Y87 package, then you can use the stock one. Otherwise, the V8 rack is needed.
                              Re: The 5.3L Swap?
                              The difference between the 6 & 8 one is the input shaft angle.
                              Team NoVa
