Lower manifold gasket on the GTP block - FirebirdV6.com/CamaroV6.com Message Board
  • Lower manifold gasket on the GTP block
    Im currently putting together a GTP shortblock and I see on the block there are 2 holes on each side of the front and back of the block where the lower manifold sits and the rubber peices from the gasket set go there and they wont fit becuase of those 2 holes.....what manifold gasket set works with these holes? They fit perfect on my L36 block but not on this one......seems even the 97 GTP shortblock had no holes so maybe its a 99+ block? Thanks
    Past Ride
    1995 Firebird A4 3.8 Turbocharged -- 12.50 at 108
    (If you dont know me, you haven't had a V6 long enough)
    Current Ride
    2006 Mitsubishi Evolution GSR
    www.myspace.com/shane1015
    i think i know what you're talking about... i know the 2000 blocks have a lot of differences in terms of mounting brackets, etc. can you maybe dremel the holes in there so your gasket set will fit?
    you might be on to something with the 99+ block. are you building this shortblock for your car or for a FWD application?
      building it for my car.....its all done except for this damn gasket prob.
      Past Ride
      Current Ride
        http://uploads.fakeleg.com/tmp/block.JPG
        red dots is where the holes are
        Past Ride
        Current Ride
          so... they are just below the mating surface i'm guessing. what would you say their diameter is? are they perhaps just cleats for the gasket?
            but if they werent there the gasket slips right over the edge of the block and sits perfect...with those in the way it doesnt seal real good and would leak like a whore....im wondering if theres a special piece that works for this block.
            Past Ride
            Current Ride
              your best bet is clubgp man
              Shane
              00 Pewter Y87 Camaro-SS Hood/Chrome rims, Black Halos, Clear corners, Pacesetters, V8 K&N FIPK, 3\" B&B TriFlow, HPP3, MSD Coils, Taylor wires, Transgo stage II, Edge 3000 Stall, 180* thermo, SLP Bowtie Grill<br /><a href=\"http://www.cardomain.com/memberpage/468763/1/\" target=\"_blank\">Carro</a>
