Driver Window Problem HELP! - FirebirdV6.com/CamaroV6.com Message Board
  • Driver Window Problem HELP!
    Ok I did some searching and nothing has actually come up with the explanantion I needed so here it goes...
    its a 97 RS with power windows.
    the passenger window works perfect. The driver window used to work perfect then all of a sudden one day got stuck. Then after about 15 mins it went all the way up. This problem got worse and worse until the window doenst move anymore. I replaced the switch in the door(with the buttons on it) and the passenger window works even better than before.
    heres the weird part... i have an autometer volt gage.
    when i hit the passenger button, u can visibly see power being drawn by the gage moving.
    when i hit the driver button...nothing...as if no power is going to the motor. this all happened in about 3 days time and im not sure if i need a window motor or not because every once in a while the driver window will move an inch or two its driving me NUTS! yours thoughts!? Thanks guys
    Re: Driver Window Problem HELP!
    sounds like a bad window motor
      x2... there's no power bc the motor has some sort of thermo switch or something that cuts off power if it gets too hot, and they get too hot because they wear out and become too underpowered to lift the window
      Custom interior...
      TEAM NoVa
        try a new harness
        WAWA-A-HOLIC
          I had the same problem i was listening to music my friends hated and put it really loud and lowered the windows... then it just randomly started raining.. but anyways.. my power window harness was messsed up so i just cut them and extended the wires
          Wait, Is that a V6 or V8?
            ding!
            gold star!
            it'll move until the motor gets hot and it'll die.
            Follow me!
            Or this
              Bad motor for sure.
                ok cool thanks guys i just wanted a second opinion..u never know with fbodys lol
                  one more thing...as i look up window motors...it says that the same motor will fit either the driver or passenger side...are they really interchangable like that?
                    Yes, they are interchangeable.
                      ebay is cheap
                      1997 Camaro LS1 RS
                      1994 Camaro - Sold
                      1999 Trans am Vert - Sold
                      A Few Mods....
