Where to install oil temperature sensor? - FirebirdV6.com/CamaroV6.com Message Board
  • Where to install oil temperature sensor?
    Would anyone know where would be the best location to install a oil temperature sender? Is there a test port on our 3800 V6 engines?
    99 Camaro RS - 3.8L V6<br /><br />Modifications<br />Exhaust: Magnaflow OBD-II High-flow Catalytic converter / Magnaflow catback exhaust<br />Intake: Shaved Airlid / 3\" PVC tub<br />Suspension: V8 springs / DeCarbon shocks / 32mm 1LE swaybar / 19mm rear swaybar
    Re: Where to install oil temperature sensor?
    You could probably T off of the oil sending unit just above the oil filter.
      that is what i did with a few cheap fittings from home depot
      WAWA-A-HOLIC
        me too
        Dave:
        00 Supercharged Camaro - RIP
        97 Turbo Camaro - Sold
          X3 , thats where I plan on doing. Or I might T it when going into my turbo since I have to tee for it so I might just tee it before the turbo so I don't have alot of fitting off the front cover.
            does anyone have a picture?
              sorry to hijack, but can i replace the original oil pressure sender with an aftermarket for a gauge with no problems? i believe i unplugged it and it ran fine. i j/ didn't know if it went to the computer at all.
                by t-ing off, do you mean tapping the oil pressure sensor? can I have both oil temperature and oil pressure readings?
                  no you dont tap the pressusre sensor. you take off the pressure sensor screw in a pipe T so now you have two oil outputs for both the pressure sensor and oil temperature sensor.
                    ooh, that makes perfect sense. thanks for the info. i'm off to home depot.
                      lol just dont forget you need a pipe nipple too, to screw the tee into the sending unit.
                        would you happen to know the size of the fitting? is the pipe nipple and t fitting a 1/4npt?
                          yea im pretty sure that what it is. but i'm not 100% sure.
