Vision motorsports spark plug wires - FirebirdV6.com/CamaroV6.com Message Board
  • Vision motorsports spark plug wires
    Anyone ever use these spark plug wires? http://cgi.ebay.com/ebaymotors/SPARK...Q5fAccessories
    My msd's have a crack in em, and I am getting a stumble in the car that I am getting sick of, and need to fix.
    wouldnt mind a 10mm wire, but I dont want to buy junk
    Re: Vision motorsports spark plug wires
    no idea, never heard of them
    http://www.bowtiev6.com/
      never used them but their probably not bad. I found these too, to help you decide.lol
      http://ma240sx.net/forums/showthread.php?tid=3629
      http://www.hondacivicforum.com/forum...d.php?p=668927
      and then this
      http://www.magnecor.com/magnecor1/truth.htm
        zzp has a 10 mm set idk if i would get 40$ ones from ebay
          i just thought about sumthing didnt you just say the other day about running a dirt slow time at the track?.... could be the issue
            possibly...although I doubt I could loose that much time from some bad plugs...
              I have ZZP's 10.2 wires and they work great, I got the wire seprators for them and so far they work great. Should last at least 10 years with the boot protectors. my last set of MSD 8.5's lasted 8 years and are still good , just wanted to try the 10mm wires. Plus I like the straight boot wires, work better with my RK headers.
                I was reading a lot of bad reviews about them on zzp...did you notice a difference going from 8.5mm to 10mm?
                  you will see no noticeable difference between them unless there is a bad one right now
                    I gotta couple that are cracked...and I get a bad stumble when going 60km/h
                      Would spark plug wires be the culprit for the stumbling? Whenever I have the pedal down more than 70-80% of the way down it starts popping real bad, like the gas isn't being combusted all the way.
                        I would think in my case it is either plugs/wires. I know my plugs are cracked...I know my fueling is fine...so I am leaning towards an ignition issue.
                          No, not really any difference, but once turboed I hope to pick up a few, if their site is telling the truth.LOL But I like them , anys because their black , I always hated the red MSD ones, I always wanted balck wires. LOL
                            possibly, or something else in the ignition or fuel system
                              well I just went with autolite performance wires (basically stock replacement) and AC delco irridium plugs...cheap replacement and I was over the border picking up my c5 rims...so it was just easier this way... saved myself some money.
