replaced heater core - FirebirdV6.com/CamaroV6.com Message Board
  • replaced heater core
    I replaced heater core and top off fuild in my 99 v6. but still no heat.. the floor boards are dry and there is no leak that i can tell.
    Re: replaced heater core
    Is the engine getting up to normal temp?
      air bubble in the coolant system? Hoses in/out of heater core hot or cold?
      http://www.bowtiev6.com/
        the engine is running normal temp. and tonight its working fine, but yesterday when I check the lines the metal on was cold (cant remember if thats the in or out) but the rubber one was hot.
          Sounds like air bubble. Hopefully it's out now.
            you need to bleed the system
