leaking coolant - FirebirdV6.com/CamaroV6.com Message Board
leaking coolant
  • leaking coolant
    So I got home today and noticed puddles of coolant under my car. I'm hoping its the water pump and not a head gasket. How can I make sure that its not a head gasket and it's the water pump for sure? It's a 2000 3.8 v6 with 133k miles with the original water pump. Anyone know about how much it will cost to fix it?
    <a href=\"http://www.fbodyelpaso.org\" target=\"_blank\">www.fbodyelpaso.org</a> A4 stock 3.42 and LSD not Y87,SLP cold air induction, whisper lid, k&n filter, flowmaster 80 series, hypertech, 160 powerstat thermostat, t/a front bumper, functional nostrils, pacesetter headers best et: 15.9 at about 4800ft
    Re: leaking coolant
    check your oil...if it looks milky, than its your head gasket. if not, it's something else....and it can be a number of things.
    dry off everything start the car and watch for the leak.
    WAWA-A-HOLIC
      Re: leaking coolant
      Get a flashlight and look at the bottom of the water pump. The fluid should be coming from there. I just changed my son's. His started the same way.
        Re: leaking coolant
        I just checked the oil and its fine. As soon as I started the car it started leaking coolant and it seems to be coming from above the water pump.
          Re: leaking coolant
          I paid about $40 at Autozone with lifetime warranty. The have another model for $27 with only a 1 year warranty.
          It is not hard to change.
            Re: leaking coolant
            Do you mean somewhere higher than the water pump or like the top of the water pump gasket?
            TEAM C6V6
              Re: leaking coolant
              right above the water pump.
                Re: leaking coolant
                vague.
                TEAM C6V6
                  Re: leaking coolant
                  Double check that one of the two plastic 90* elbows aren't cracked. It's pretty common for them to dry out and break, causing a leak. They're kind of hard to see, but a flashlight and some sort of mirror (I used a dentist's flexible mirror) should give you a good view.
                  '99 Camaro
                  '04 Saab 9-3 Aero
                  '90 Audi Coupe Quattro
                    Re: leaking coolant
                    You read my mind Pace. To the OP, I'm going to be really surprised if it is not this after reading your description of the problem.
                    Daily: '02 Black Yukon Denali
                    Toy: '06 Torrid Red GTO
                    Gone: Powerdyned '02 Pewter Camaro
                    Gone: '07 Charcoal Yamaha R6
                    Gone: Ex-wife, lol
                      Re: leaking coolant
                      Yeah, that's what I was trying to figure out. I quit.
                      TEAM C6V6
                        Re: leaking coolant
                        Where exactly are these elobows located? I've got the day off so I'm gonna work on it today.
                          Re: leaking coolant
                          Heres a picture I circled the area with gray where the leak is coming from.
                            Re: leaking coolant
                            What circle? Can you use maybe red, or blue, purple, green, orange, yellow or indigo?
                            - Nevermind, I see it.
                              Re: leaking coolant
                              I agree with the others, it does sound like those plastic elbows, they usually break around the neck, replacements are cheap and the install isn't that hard at all.
                              1998 Chevy Camaro 3.8
                              1997 Chevy Camaro Z28 - SOLD 7-23-2011
                              1996 Chevy Camaro Z28
                              2001 Pontiac Firebird Formula
