I just replaced my water pump and Im hearing alot of popping noise from the pump and my engine coolant temperature isnt rising. Plus I lost alot of antifreeze and I tried adding some but my radiator is instead overflowing??? Whats the problem here???
Just replaced water-pump, POPPING sound and temp wont rise...
Re: Just replaced water-pump, POPPING sound and temp wont rise...
Are you filling it the right way? Have you opened the bleeder screw on the thermostat housing?<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
UPDATE: Popping sound was the pulley, it was still loose even though I thought I had tightened it... It's fixxed now... As for the temp - it goes up to 210 and stays there so I think everything is fine now...
Originally posted by Bird_Of_Prey View PostAre you filling it the right way? Have you opened the bleeder screw on the thermostat housing?
Originally posted by techsan23 View PostIt'd be worth pulling back off of there to see if the impeller on the pump is hitting something. Did you replace the thermostat?
Thermostat was recently replaced no more than 4k miles ago (old one got stuck open and caused my fans to stay on)...
Although the car is running fine, no leaks, no sounds anymore, regular temperatures...
How do I fill the coolant and bleed the system just in case? Because the car would only take half a quart of 50/50'd dexcool... anything over that would come spewing out the cap or overfill the reservoir but I'm sure I lost more than that when I pulled the pump.1997 Camaro RS W/T-Tops<br />All Stock / 200 HP
just open the bleeder screw and let it go until nothing but a stream of coolant comes out. pretty easy.
Follow me!
Or this
