So last night I'm driving and all of a sudden my Camaro jerks hard and stalled so I had it towed to the house, now when I try to start it it hesitates for a split second and won't fire over. I have tested the fuel system with a pressure tester, and even the fuel pump primes when the power is on. What gives?
Since you verified the fuel is fine make sure that you're getting air and spark as well. Check for a bad ground. Check that the AUX power is connected on the driver side. Check for blow fuses, etc..
Hesitates and won't fire over? So it's not turning over at all? Not much to go on, but with that description, I'd say a bad battery or alternator or connections thereto.
