Thermostat question (please..) - FirebirdV6.com/CamaroV6.com Message Board
  • Thermostat question (please..)
    hi guys
    I need a little help
    any of you could tell me how many degrees is the original thermostat in my 3.8 AT 1996?
    you know of any thermostat that operates at a lower temperature?
    I have a little problem with the temperature of my camaro, I already solved with cleaning my radiator but I would like to lower the temperature
    any recommendations?
    thanks again:tup:
    Re: Thermostat question (please..)
    195*. Go with a 180* thermo if you want a lower one
    http://www.bowtiev6.com/
      thanks..
        hypertech sell the 160 (part 1009)
        http://www.gvperformance.com/store/i...d&productId=30
        this will be a better option than the 180 or there will be some technical details I should know?
        Hypertec not appear in information, but in the GV website claims to be for the 3.8
          160 works too as long as you are not in cold climates where you need nice hot heat. So generally most people go with the 180*. But yea the 160* hypertech one does fit our cars, I ran the same one in mine for quite a few years.
            thanks again 97rs
              i wouldnt get the 160 thermostat
                Elaborate?
                  Originally posted by Atrum Rosa View Post
                  Elaborate?
                  because its pretty pointless.
                  not to mention the engine was designed to be run with a 195/180 F thermostat
                    the newer cars approx 99+ like a 180* over the 160* and sometimes throw a code. He has a 96 so a 160 is just fine unless like I said he runs it in the winter.
