Another oil pressure question - FirebirdV6.com/CamaroV6.com Message Board
  • Another oil pressure question
    My oil pressure issue sounds like a lot like others I've read here in the forums, the gage bounces around, and now its started reading a bit low, ie..Wednesday it would read at 60psi now Friday it reads usually centered between the first tick mark on the left and the 60psi reading sometimes just 30. Where is the oil pressure sensor located on a 99 Firebird V6 so I can check it?
    Chris
    Re: Another oil pressure question
    If it bounces check for a rear main seal leak. But mine did that, and an oil stabilizer helped greatly. The Lucasoil one works, but honestly if you can get Powerdyne TX7 do it. My pressure sits at 80psi now.
      Thanks I'll give it a try. Can't find the powerdyne it seems at advance auto but did find the lucas oil stabilizer.
        I think Jiffy Lube is the only place you can get TX7...
