Put the car on the rollers with the car not hooked up to the ministry to see if I would pass....car runs clean as hell for the driving test (made me feel great about my own tune) However the idle test my Hydo carbons are through the roof...limit is like 200 or so and I'm at almost 300...that was idling at stoich on the AFR, as well as we pulled the vacuum line and leaned it right out to about 17-18afr at idle and it didnt help any...
Anyone know how I might be able to get the HC count down?...
Install a stock cam.LOL I don't know
I improved my HC and NoX levels by installing a new catalytic converter and O2 sensor.
Another trick is to add a pint of denatured alcohol to a 1/4 tank of super unleaded as well before the emissions test.
Go with single electrode spark plugs versus those fancy 2,3,4 pronged spark plugs. Can't fool electricity, it follows the path of least resistance. I enjoy crisp starts with my AC Delco Iridiums.
Black \'96 RS Camaro, 3.8 V6 Series II, M5, Stock 200 HP, 204K miles! Stock \'91 Firebird 3.1 V6 automatic w/ overdrive. 266,400 miles on it. \'83 Pontiac Trans Am,305 LG4, Cowl Induction,Borg Warner 5 Speed,T-Tops,Gale Banks Exhaust System:$800 obo
is there a way to do coil per cylinder setup on our car with that?
Not possible considering the ICM and PCM are controlling only three coils. You need to find a way to control 6, and you're going to need more than just an MSD DIS-4. Wouldn't see the point unless you're building something insane....
1995 Pontiac Firebird
