My car - FirebirdV6.com/CamaroV6.com Message Board
My car
  • My car
    2000 Chevrolet Camaro:
    3.8 V6
    A4
    96 K miles
    Engine bolts-on: December
    • Air silencer delete
    • High flow air filter (K&N)
    • Lid (SLP)
    • Ram air (Fast Toys)
    Exhaust:
    • Catback
    • Headers with Y-pipe (Pacestter)
    Drivetrain:
    • 3:42 gears (Factory)
    • One piece steel drive shaft (Factory)
    • Posi-differential (Factory)
    Suspension:
    • New 17 in wheels and tires
    • Shocks (Koni Str)
    • Front bushings (Moog: Tie rods, Control arm upper and lower, ball joint upper and lower)
    • 35/22mm hollow sway bars
    • Tubular lower control arms (Founders performance)
    • Tubular pan-hard (Founders performance)
    • Fast-steering ratio
    Brakes:
    • Brake pads (Akebono Performance Ultra Premium Ceramic Pad)
    • Brake fluid
    • Rotors (Duralast)
    Cooling system:
    • Aluminum elbows (Advance Auto parts)
    • Coolant flush (Dexcool)
    • Radiator (Made in China)
    • Thermostat (180°, Duralast)
    • Upper and lower radiator hoses (AC Delco)
    • Water pump (Duralast)
    Ignition:
    • Battery (Ever Start Maxx)
    • Sparkplugs (NKG)
    • Sparkplugs wires (Bosch)
    Emissions:
    • Oxygen sensor and extension (Denso)
    Exterior:
    • Berger panel with an Ls1 emblem (about +100 more hp)
    • Halo headlights
    • Red painted calipers
    • SS Hood
    • SS spoiler
    • Turn signals lights
    Interior:
    • 30th anniversary seats and door panels
    • Dash pad
    • Sound system (Radio, 4 speakers, amplifier and subwoofer
    Other:
    • Belt (Goodyear Gatorback Poly V)
    • Power Steering pressure hose (AC Delco)
    • Upper and lower intake manifold aluminum gaskets (Fel-Pro)
    I might be forgetting something.
    Next break (December) modifications: Sub-frames or TA cover, bump stops, spark plug wire heat protectors and fuel filter.
    Maybe next I’ll add a camshaft.
    Re: My car
    Exhaust clip:
    http://vid763.photobucket.com/albums...psac8758c7.mp4
      Re: My car
        Re: My car
        Before:
          Re: My car
          Ls1 steering rack and pinion?
            Re: My car
            Good looking Camaro. I hope you don't mind me saying, but I think you should remove your LS and Z28 badge. Take pride in your V6.
              Re: My car
              the z28 badge is gone, the ls1 badge is going to be replace with a 3.8 ( http://www.ebay.com/itm/360523226530 )
                Re: My car
                Lots of work and $ went into this car and it shows nicely
                Phil
                  Re: My car
                  Very nice!
                  BTW, Id like to take those badges off your hand :)
                    Re: My car
                    Looks awesome! I'd like to get some of those seats for mine. Thanks for sharing!
                    2000 Camaro 3.8 v6 M5
                    Flowmaster 80 series muffler, B&M ripper shifter, SLP grille
                      Re: My car
                      Thanks everyone
