My AC blower works on all levels but it is blowing slower then usual. I felt under the passengers side center front console and felt some water dripage. When I turn the air on it sounds like its coming out of some other vent but I know its not full pressure.
Please help guys thanks.
1996 Firebird-Y87:SLP Cold Air Intake,Y87 Perf. Package: 3.42 Gears w/ Zexel-Torsen LSD, Sport Steering(14.4:1 ratio), Dual Exit Exhaust,800 watt Pioneer Amp and Two 10\' subs with a custom trunk enclosure.
what selector do you have it set to? make sure that it;s only coming out the vents that you have selected and not partialy out the floor or defrost. make sure that the fan runs on all speeds as well
it could be a vaccume leak...heatercore remotly possible?check lines for vacc
92 25th rally sport garage baby, 97 30th rally sport, 01 camaro garage baby. obsessive compulsive camaro fan. id rather push a camaro then drive a rice burner.
Well It worked fine today.....No leak or anything ....is it hinting at something to come? thanks guys
could be lots of things. if it;s coming out teh vents but at some times not strong it could be anything from battery or alt efecting system voltage or the blower motor going south or having a bad connetion
4 days ago
