Final finished designing, fabricating and installing my "OEM" PCV A/O separator.
PCV Air/Oil Separator Installed
RavenTags: None
Looks good. Can you take a engine pic that shows all of it in one shot?Last edited by ssms5411; 01-26-2019, 11:13 PM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Looks good! So is this basically a "catch can" that is inline with the stock hoses? What would be the advantage of this over say a conventional catch can?
- 1 like
Originally posted by LETZRIDE View PostLooks good! So is this basically a "catch can" that is inline with the stock hoses? What would be the advantage of this over say a conventional catch can?
Moroso p/n 85632
GM molded 3/8" ID PCV line from PCV valve to A/O Separator then another GM line to Y with EVAP purge line into TB.
Raven
I am confused? My understanding of catch cans is that is how they are meant to work? Pull the oil from the air so it doesn't cake the valves? Or maybe I am not understanding one vs the other?
Originally posted by LETZRIDE View PostI am confused? My understanding of catch cans is that is how they are meant to work? Pull the oil from the air so it doesn't cake the valves? Or maybe I am not understanding one vs the other?
https://www.moroso.com/air-oil-separ...all-body85632/
Last edited by FirebirdGT; 01-29-2019, 12:12 AM.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
Just read up on it, makes more sense now. Air oil separator cleans the air and sends clean air to the engine and the oil back to the crankcase while a catch-can just holds the oil from the blow by.
Nice looking setup
How would you run it for a boosted setup, just the same but plugged TB?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by ssms5411 View PostHow would you run it for a boosted setup, just the same but plugged TB?Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
Originally posted by FirebirdGT View Post
No - you need to get the "cleaned air" back into the intake after the MAF - problem is you have a pressurized TB, and you also need to get air into the crankcase.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Yeah , I figured it would be a problem, don't want to blow the dipstick out. I haven't had any problems the way it is ,so I'll just leave it.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
How did you, or any anyone else, block the hole from the PCV valve into the UIM? Curious.
yeah, just put a plug into the TB, on ours its the only way to run a boosted setup doing that and running a valve cover breather.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
Yes - plugging the TB hole for the air passage to the crankcase - but what about the hole into the UIM from the crankcase through the PCV valve? Leave it and let the high UIM pressure keep it shut?
