Hello, I am new to the forum but excited to be a part. My question now is the order, from front to rear, of the intake and exhaust valves / pushrods for both driver and passenger sides.
I need to adjust valves and understand there are slight differences between the two. Any help would be greatly appreciated!
Thanks!
teejay
If it’s like the 3800 II you just need to torque the rocker bolts to factory spec.
