i don't mean it's over heating, but i'd like to have the car at 180* or less when it's running, even at idle. none of this 210* crap. i know a fan switch is probably the easiest way to go, but is there any other way?
keeping engine from getting too hot
\'98 Camaro - SOLD<br />Best E/T: 15.489 @ 86.48 MPH<br />60\': 2.131<br /><a href=\"http://members.cardomain.com/skorpion317\" target=\"_blank\">members.cardomain.com/skorpion317 </a><br />1998 Saturn SL2<br />Official <a href=\"http://www.njdisturbance.com\" target=\"_blank\">NJ Disturbance</a> bracket racerTags: None
First buy a 180* or a 160* thermo. That will help out alot if you still have the stock 195. A manual fan switch will help a little, but to be honest, if you are going down the freeway, you dont need your fan on. So in theory you are just running another power source for no reason. Of course you could turn it off, but noone ever does. I know SLP sells a fan switch that will kick in at like 180* instead of the factory whatever it is. Like 980*. [img]smile.gif[/img] I have no thermostat in mine right now and good lord it runs at about 160-170 nonstop excpet at stop lights, it will rise a little. But it surely doesnt rise as much as when I had my 160*. But I will probably put a 160 back in for winter. Good luck. ;)Jordan<br />15.09@90.7<br /><a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=21\" target=\"_blank\"><b>1995 Camaro 3.4 M5</b></a>
a thermostat doesnt nothing to effect the temp., it just slows down the heating up process by having the coolant kick in earlier.
having no thermo is not a good idea [img]graemlins/popcorn.gif[/img]
if you want you engine to run cooler, you need a fans switch or go the PCM tuning direction [img]smile.gif[/img]
Fan Switch: Worthless unless your thermostat is open and your water pump is running. All your fans do is cool down the coolant. Get a 180 or 160 deg thermo and your ok though.
Lower temp thermo: Worthless unless the fans are set to turn on earlier then stock. Otherwise you will just be running "hot" coolant through your car untill it reaches the stock heat range for the fans to turn on. Tuning or Fan switch is a MUST if you want it to have any effect on your car.
Electric Water Pump: All around good idea. Flows more then stock water pump and you can run it without the engine running. Great for track use and I prefer having one no matter what. Frees up horsepower, better flow, and you can cool the car down in minutes if need be. Not a must by any means but definetly helps cooling.00\' firebird v6 5spd<br />201rwhp ---- 230 rwtq<br />\"Everyday I grow stronger...and further from you.\"<br />WARNING: Do not take any of my comments seriously unless they are technical in nature and then only at your own risk
i was under the impression the fans dont cool your coolant. it cools your motor
The coolant cools the engine internally by drawing the heat out of the metal of the engine into the coolant. Thus lowering the temperatures. The fans are there so that when the coolant exits the engine it goes by the radiator and is cooled down there. When the engine reaches a certain temperature however the the fans turn on. The fans force more air through the radiator thus cooling the coolant quicker. In exchange this lowers the temperature of the engine. Remember your engine temperature only measures the temperature of your coolant/water ;) Not the actual temperature of the metal.00\' firebird v6 5spd<br />201rwhp ---- 230 rwtq<br />\"Everyday I grow stronger...and further from you.\"<br />WARNING: Do not take any of my comments seriously unless they are technical in nature and then only at your own risk
Have you ever even looked under your hood? It doesn't take a rocket surgeon to figure out which direction the fans are blowing.....2000 3.8L Firebird, Silver Metallic<br /><br />\"Yes, London. You know, fish, chips, cup o\' tea, bad food, worse weather, Mary f***in\' Poppins, London!!\"
:rolleyes:
a chevelle's fans i work on blows on the motor. im sorry if i dont fequently check which direction my fans blow. and i never made it seem like my comment was the all mighty law of cars. and dont act like you know everything cause you dont
[ September 05, 2004, 11:50 PM: Message edited by: BLLDOGG ]
If it ain't blowing air at the radiator then its sucking air through the radiator ;) Irrelavent arguement.00\' firebird v6 5spd<br />201rwhp ---- 230 rwtq<br />\"Everyday I grow stronger...and further from you.\"<br />WARNING: Do not take any of my comments seriously unless they are technical in nature and then only at your own risk
sucking air through is what i thought it did. well now with the great support of memphis_raines, i and others reading know now. thank you
Yep.. Even the older cars worked on the principal of pulling more air through the radiator via the fan shroud. Sure it blows on the motor too but the purpose was to get more air across the radiator, thereby cooling the coolant.RD in AZ<br />2001 V6 Camaro, A4, Mystic Teal<br /><a href=\"http://www.azfba.com\" target=\"_blank\">www.azfba.com</a><br /><br />Mods so far:<br /><br />Brand new wiper blades... Hah!!<br />T/A Diff Cover and Stud Kit<br />\"Dremel\" modified factory lid with K&N filter
Blowing cool air onto the engine itself serves next to no purpose. Pretty much any fan(s) in the engine bay are there to pull more air over the radiator's fins, thus better cooling the liquid moving inside of the radiator.
As for the temp. Your car should be running around 180 while you are moving. If you just let it idle, the fans should kick in, keeping your temp around 210 while sitting at idle. If it goes this high, there is no cause for alarm. GM wouldn't have made it this way if it was going to hurt the engine.
I can understand if you want to cool the engine off more in the staging lanes at the track or something, but the fact of the matter is, for everyday driving, you aren't going to hurt anything letting it run at stock temps.1997 Cayenne Red Metallic Camaro<br />3.8 V6 M5<br />SLP Cold Air Intake<br />Ceramic Coated Pacesetter Headers <br />Flowmaster American Thunder Catback<br />Full 3.42 & Disc Break Rear End Swap
I can understand if you want to cool the engine off more in the staging lanes at the track or something, but the fact of the matter is, for everyday driving, you aren't going to hurt anything letting it run at stock temps.00\' firebird v6 5spd<br />201rwhp ---- 230 rwtq<br />\"Everyday I grow stronger...and further from you.\"<br />WARNING: Do not take any of my comments seriously unless they are technical in nature and then only at your own risk
