Low beam went out on pass. side. I replaced the headlight...nothing, high beam on pass. side will not work either. The motors still work great and the driver's side headlights both light up great.
I checked the connector 3 times and cleaned out all the corrosion i could till I saw shiny metal.
Both LB and HB headlights are plugged in.
I'm starting to think maybe a wire is damaged somewhere along the line. (please god no)
2000 Firebird 3.8, auto, flowmaster 80, taillight blackouts, 02 formula swaybars, poly endlinks and energy support bushings, 1 1/2in cut springs
Ok, found a multimeter at work.
Pass side :11.9 volts
driver side:12.1 volts
I put a working headlight on the pass side and still nothing. I'll check the grounds, if that ain't it I'll prolly cut the connectors off and splice the wires together.
I checked the grounds and its the metal prongs inside the connector for the headlight motor. Common corrosion but how do I clean the post? The post looks black like it was burned.
