Need to get Horn to work - FirebirdV6.com/CamaroV6.com Message Board
  • Need to get Horn to work
    I need my freggin horn to work.I think its a fuse.What the horn fuse labeled as? I checked them out and cant find the one for the horn.
    What year??
    Matt
    1998 Mystic Teal Camaro M5
      91 bird
        Sorry, can't help you there.
        Do you have a Haynes or Chiltons manual, maybe? You could easily check the schematics and find which fuse it goes to.
        Matt
          forget the horn and install a speaker/bullhorn thing like the cops have so you can just yell at people :D
          i cant help u if u really want your horn to work- i saw a chick with the speaker thing, thot it was pretty cool
          -RJ \"Like trail mix I\'m a lil sweet but mostly nutty\"<br />Metallic Blue 2001 3.8 Firebird M5<br />FRA,Smoothed Air lid, Homedepot Intake, K&N Air Filter, MSD Coils & Plug wires, Iridium Plugs, Flash Tune, 2.5 Flowmaster Catback.
            uhh on the back of your fuse box cover pannel, there should be a diagram that names the fuses.. if not take all your fuses out and replace the broken ones... just remember to do it one at a time!!!
            Mystic Teal Metallic
            ET:15.1 NA 14.3@96 MPH 75 Dry Shot
              I looked in my haynes and showed no horn fuse...I check the fusebox and found every single electrical part except the horn...
                There's probably not a single fuse just for the horn. You gotta look at the schematics and follow the wiring to see which fuse it uses.
                Matt
                  3rd gens, it goes w/ the cigarrete light I believe. If it don't work it could just be that you're horn/horns are busted, ie get new ones, both of mine were blown, eh it sucks but they're only like $10 a piece at autozone.
                  ---Niño---<br /><i>95\' silver 5 spd</i>
                    Yes, the fuse is shared with the cig lighter and should be found behind the left panel between steering wheel and door. I had a problem with my horn blowing the fuse every time I used it. Eventually I tracked this down to a worn thru wire. The wire to one horn was touching the other horn. This eventually rubbed away all the plastic and gave a metal on metal contact. A piece of insualtion tape was all that was required to remedy the problem. Now everyone that gets in my way gets a good blast on the horn ;)
