spark plug question - FirebirdV6.com/CamaroV6.com Message Board
spark plug question
  • spark plug question
    Changin the spark plugs on a buddy's '00 v6. The metal heat shields that are on the boot.. Twist off, screw off, or just pull on em till they come off?
    <a href=\"http://www.cardomain.com/memberpage/771259\" target=\"_blank\">www.cardomain.com/memberpage/771259</a><br />\'02 3.8 a4<br />Mods: Nothing worth mentioning yet, but I have plans for it.<br /><br />\"Every time a Honda dies, a Chevy gets its wings.\"
    pull em till they come off [img]smile.gif[/img] and have fun!!!jk...its a PITA...though, it might help if you do kinda twist them and 'play' with them a little bit. I found it easier to do the job from over the car, but alotta guys will say that it is easier from the bottom. just go for it and find out for yourself! have fun!
    2000 Navy Blue T-top Camaro A4<br />TSP Rumbler <br />Carsound Hi-flo Cat<br />!MAF screen<br />Whisper lid<br />HPP3
      wear gloves! youll tear the flesh right off ur fingers. i know it happened to me.
        Just pull them. Do it from the bottom, on a lift, I did mine in about 10 mins with the hardest one being the back drivers side.
          Changing the plugs sucks serious ****ing balls. Took me 3.5 hours of aggrivation and throwing tools to do all 6. The boots pull off and then throw them as far away as you can...you thank me when you chuck that instead of your socket. Then I just put real boot plugs on...those pita silver ones of whatever fabric they're made of.
          Andrew
            I wish I had a lift in my garage.....
              Roll the car over, they should be easy to get to.
              2001 Firebird 3.8L V6 M5,<br />It once had....<br />NX Nitrous Wet Kit, ZZP X-P Hot Cam, <br />3.42 LSD, Pacesetter Headers, <br />36# Injectors, HP Tuners<br />322 RWHP, 379 RWTQ<br />13.596 @ 102.56 w/100 shot
                '00 has tubular manifolds. The spakplugs are easy to get to from above. hardest part is the stock boots. like above post...just sorta twist them back and forth a bit to loosen them up...then pull them off. no big deal. gloves are a good idea...no problem here though.
                pull from the boot AND the wire...not just the wire. you might pull the wire right out of the boot if you do not pull them out together.
                The three hour sparkplug changes are most always from the earlier years with the log manifolds.
                01 Firebird A4 3.42
                Powerdyne @ 6 PSI
                and other mods
                  [img]graemlins/rofl.gif[/img] [img]graemlins/rofl.gif[/img] [img]graemlins/rofl.gif[/img] that would make it real easy
                  Follow me!
                  Or this
