I need help on wide open throttle responce. I was cruising the other day around 75mph and I was noticing that when I floor it I have no intial responce. Sure I can build the speed up but is ther anything I can do to get the responce I want?
I was planning wires, plugs, and maybe a K&N filter. What about the scoop thing on the bottom to get more air flow???
\"If I have seen further, it is by standing upon the <br />shoulders of giants.\" (Isaac Newton)
i wouldn't get a k & n for your stock airbox, it doesn't help, a waste of your money. i would go with a CAI of some sort, that's probably your best bet--i mean there are a lot of things to help that top end, like gears and such...but your looking at a good bit of money. i made myself a homemade CAI and it helps a lot, and i can tell. i noticed you have a 96 camaro...i have a 97 and put up a webpage on how to build your own intake for a 96-97 f-body, so that will definetely be to your advantage to check out. maybe it will help you...
