i got my car running again, i replaced the IAC and it started working, but now after it is running and i hit the gas, the idle goes up and stays there, and even sometimes goes even higher, what could i check??? I already disconnected the Negative battery cable after i installed the other IAC
Won't Idle correctly....
IAC?www.turbov6camaro.com
1997 3800 Series II Camaro
maybe your throttle is sticking?www.turbov6camaro.com
Originally posted by 98_birdman:
I've been having trouble correcting my idle all today and I just went to take off the throttle body to change the idle speed and coolant leaked out....what is going on???www.turbov6camaro.com
Originally posted by Fredless:
TPS (throttle posistion sensor), the smaller sensor on your throttle body.www.turbov6camaro.com
Yea I would make sure you installed that IAC valve correctly. If you have to just to be safe, take it out and clean the IAC bore with some carb cleaner and a pipe brush to remove gunk. I took my whole TB off and cleaned it. There was all kinds of crud from the PCV system so i soaked the whole thing in gas and took a toothbrush and cleaned it all out and did great afterwards.1995 Arctic White Camaro. 3.4L/A4<br /><br />\"Stupid men make mistakes, wise men learn from mistakes\"
