Jetchip SCU2000 Installation!! - FirebirdV6.com/CamaroV6.com Message Board
  • Jetchip SCU2000 Installation!!
    Hey Guys,
    I really want to install this chip but I dont got the instructions. Where exactly to I plug it in to and where do I put the module? Anyone got any detailed instructions and pictures? Or can someone scan the instructions for me?
    Thanks
    Whisper Lid, SLP CAI, KN Filter, 3\" HiFlo Carsound Cat, full 3\" mandrel-bent piping, Flowmaster 80s, Casper O2 Sim, BM Tranny Cooler, Vigilante 3300 Torque Converter, Corvette Servo, 3.42 gears, SLP take-off LSD, Manual Fan Switch, & 160 Thermostat.
    Someone has got to know this right???
      Gimme some time If I get a break I've got a scu2000 sittin at home in the original package with instructions. I'll either pick it up or I'll post em lata!
        Thanks a lot man!!! I really want to get that thing installed tonight. Hopefully it's not that complicated.
          how fast can you go after you take off the ghey governer? [img]smile.gif[/img]
          \'01 Trans Am WS6 5.7L M6<br />Stock now w/ K&N and whisper lid<br />Coming soon: B&B Triflow catback, MAF, 85mm throttlebody, headers, supercharger?
            After you remove the speed limiter from what I understand the speedo just stops at 110 and you keep accelerating!
            Jet SCU2000 Installation Instructions
            1. Disconnect the negative battery cable
            2. Locate the fuse/relay center under the hood, drivers side, in the front fender well
            3. Mount the scu2000 on the fender well using the supplied velcro tape
            4. Attach the black wire from the scu2000 to a suitable ground
            5. Route the wiring harness down the underside of the vehicle. Be sure the wiringharness doe not lie close to or come in contact with the exhaust system of the vehicle
            6. Disconnect the Vehicle Speed Sensor harness, located on the tailshaft of the transmission, passenger side
            7. Plug the Vehicle Speed Sensor wiring harness into the scu2000 harness
            8. Connect the other end of the scu2000 into the Vehicle Speed Sensor tailshaft connector
            9. Use the supplied tie wraps to keep the wiring harness from dangling or coming in contact with the exhaust
            10. For a '96-'99 Camaro/Firebird connect the red power lead, using the brass fuse adapter, to Right/Left Door Headlamp Fuse(this is a 12 volt continuous power source)
            11. This is for and Impala SS so I'll skip it
            12. Recheck the wiring harnessrouting and all connections for proper installation
            13. You may now move on to "setting and adjusting the scu2000"
            14. After you have properly set and adjusted teh scu2000, reconnect the negative terminal of the battery
            Thats all the instructions
            the jumper in the little circle should be on "-" to have the speed limiter off
            Drop me a message or email me if you need me to try and take a pic of the 6 images in the instructions or need to know exact settings!
              Where is a good place to buy a chip for the car
              1998 black convertible camaro<br />rasied air box,free ram air , colored inter knobs,b&m shift kit, race magnum muffler, 3 1/2 crome tips, no cat,clear turn signals, custom front grill ,neons
                Thanks so much!!! Is it ok if you take some pictures??? And what are the settings for these??
                Stock Gear: 3.08
                Modifided Gear: 3.42
                Stock Tire: 235/55/16
                Mod tire size: 255/45/17
                  Like i said before the stock tire is 3 stock gear 3 mod gear 5 mod tire try 5, when you mess with the mod tire setting the higher numbers seems to take the rpm a little higher and lower settings shift earlier try mod tire 5
                    <blockquote>quote:</font><hr>Originally posted by bluecmaro96:
                    Like i said before the stock tire is 3 stock gear 3 mod gear 5 mod tire try 5, when you mess with the mod tire setting the higher numbers seems to take the rpm a little higher and lower settings shift earlier try mod tire 5<hr></blockquote>
                    Everything there is correct except the mod tire leave that one on 3 as well with your old/new tire combo your speedo will only be off a fraction of a percent! But like he also sead you can change it to a lil higher for shift point changes!
                    I sent you all the setting in your email as well!
                    [ June 13, 2002: Message edited by: Nachius ]</p>
                      What did you guys use for the power wire? I'm not sure which wire under the hood is 12v.
                        Just hooked mine up today.
                        The instructions say to attach it to either the LH HDLP DR or RH HDLP DR located in one of your fuse boxes. Those are for the headlamp door modules, a continuous 12v power source. I did mine like that. I wished I would have just hooked it directly to the battery. That would have given me a little more room to avoid the exhaust. I ended up burning some of the loom, but it missed the wires. [img]redface.gif[/img] . I used the plastic straps that they sent, but ended up using a lot of duct tape to the underside of the body, and inside of the engine bay against the firewall just to be safe. Gonna rewire it later, so that it looks better.
                        [ June 14, 2002: Message edited by: AMinor65 ]</p>
                        <b>1998 Firebird 3800 Series II, A4</b><br />Direct-Flo Lid,K&N Filter,DEE TB Spacer,TPS-TEC,ZZP Mini-AFC,Raised and Cutout Airbox 7mm,BMR STB & Boxed LCAs,KYB AGX Shocks,Drilled/Slotted Rotors,180* Thermo,2.5\" Catco Cat,Dynomax 2.75\" custom catback,Kumho Ecstas/245,Jet Stage 2,3.42,Edge Racing 2870 Stall,B&M Tranny Cooler,B&M Deep Tranny Pan,LSD,AAM Girdle,1LE DS,NX Wet Kit,MSD DIS-4,MSD Blaster Coil Packs,Taylor Spiro Pro 8mm Wires,NGK TR6\'S gapped .045,ZZP UD WP Pulley,SLP Fan Switch,TT II\'s<br />N/A: 15.6342 @ 88.44 (On stock converter. Strugglin\' to beat it.)<br />Nitrous 50 Shot: 14.7463 @ 93.49
                          just use the battery, thats what i did and mine worked fine
