Running too lean in cyl# 1 and 2? - FirebirdV6.com/CamaroV6.com Message Board
  • Running too lean in cyl# 1 and 2?
    car is running like ****---like...at idle it's very rough, tries to die. taking off low it bogs until the car warms up then it feels better but not 100%. fuel filter could probably use a change, and i just ran injector cleaner a few months back... but i don't understand why this would just happen in #1 and 2 if its just the fuel filter.
    Maybe the o2 sensors?
    1 and 2 are not on the same coil so I doubt that's the problem, and this problem happened at the same time as the other.
    autozone scanned the codes- by the way.
    anyone suggest anything? i will probably do the filter/injector cleaner tomorrow
    Did the codes say you were running lean on cylinders 1 and 2, or did it say bank 1 and 2?
    ~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
      He said cylinders.
        Did he give you the codes or just look them up?
        The idiot at Autozone that scanned my car one time didn't even write down the codes, and then later looked up the wrong codes.
