my idle lately has been a little bit more rougher than it used to be. its jumping around a couple hundred RPM's. my oil pressure is also moving around a little bit. what could be the problem?
rough idle
rough idle
\'96 <b>Quasar Blue</b> Firebird A4<br /><a href=\"http://jamiethekiller@comcast.net\" target=\"_blank\"><i>jamiethekiller@comcast.net</i></a><br /><a href=\"http://www.woodlandrock.com\" target=\"_blank\">my band: woodland</a>Tags: None
one thing i did on my 3.4L was to clean the IAC sensor, just off the throttle body... i dont know if 3.8L engines have it the same (probably do), but on mine it was kept on with 2 hex screws ontop of the throttle body, i removed it, cleaned it up, (you should also clean the housing), repleaced it, reset the PCM, and boom, run much much better
hope this helps
ian97 camaro<br />black, 5 speed, t-tops, rockford fosgate cd w/4X6.5\" rockford speakers, 3\" flowmaster american thunder catback with 3\" carsound cat, SLP CAI, B&M Ripper w/leather Hurst shift knob, 5% tint.<br /> <a href=\"http://camaroz28.cardomain.com/id/ianwells100\" target=\"_blank\">http://camaroz28.cardomain.com/id/ianwells100</a>
more suggestions? can a rear main seal do this?\'96 <b>Quasar Blue</b> Firebird A4<br /><a href=\"http://jamiethekiller@comcast.net\" target=\"_blank\"><i>jamiethekiller@comcast.net</i></a><br /><a href=\"http://www.woodlandrock.com\" target=\"_blank\">my band: woodland</a>
rear main seal? no, that is soley to keep oil from seeping out of the block at the crank.
When mine idled rough it turned out to be at stuck EGR valve. A few light raps with a hammer re-seated it and the car ran fine.<b>15.41</b> @ 89.80 & 15.45 @ <b>91.64</b>, 2.21 60ft, 3,440 raceweight, using <b>OEM</b> Equipment. <br />\'98 L67/M49 w/ 134,000 miles before spun bearing. \"<i>It\'s all stock, Baby</i>!\"
<blockquote>quote:</font><hr>Originally posted by jamie:
my idle lately has been a little bit more rougher than it used to be. its jumping around a couple hundred RPM's. my oil pressure is also moving around a little bit. what could be the problem?<hr></blockquote>
Hey Jamie, stop over my house Wedsday afternoon and we can take a look at it. E-mail me: toast520@juno.com2004 Dodge Dakota 3.7 litres of raw power!!<br />Nothing but a 6!<br />Do you know for sure? John 3:18
Mine is doing the exact thing, but as hard as I look through the Haynes manual, I still can't find exactly where my EGR valve is on the 3.8. It has a picture, but there are no visable familiar components that I can pinpoint and locate, so I'm completely stuck. If anyone could tell me where to find that thing, I'd appreciate it greatly, because I've been throwing an EGR code for about a year now. Thanks.\"The Bird\" - \'95 Firebird (3.8), White<br />Suncoat Creations RamAir Predator hood with SC airbox, 30th Anniversary Ram Air-style stripes, Wings West W-Type ground effects, Last of the Breed Anniversary Emblems, Carsound High-Flow Cat, SLP Loudmouth Catback w/ 3.5\" slash-cut tips, and much more to come.
even better clarification.
i was sitting at a redlight today. idling. its idling about normal. then my oil pressure gauge just takes a small drive and thats when it got its roughest. what would making it do that? it does it ever now and a then. i've been reading things about the oil sending unit?
as;dfkjad;slkfa. i just want this thing to run correctly\'96 <b>Quasar Blue</b> Firebird A4<br /><a href=\"http://jamiethekiller@comcast.net\" target=\"_blank\"><i>jamiethekiller@comcast.net</i></a><br /><a href=\"http://www.woodlandrock.com\" target=\"_blank\">my band: woodland</a>
