im such an idiot - FirebirdV6.com/CamaroV6.com Message Board
im such an idiot
  • im such an idiot
    ok so im putting wires sleeves on my wires in the engine bay right? and im cutting the old sleeve covering the MAF sensor on the intake, i didnt look where i was cutting and cut both wires!! uhhhhhh, if anyone has an SLP CAI they know that the placement for the sensor is pretty bad so i couldnt just tape them back together. I used an "extension" wire where the cut was made to link the two ends together then used electrical tape to hold them together. What do u guys think? should i have it checked out by someone?
    edit from nb2k: thanks for keeping the titles in my forum clean in the future!!
    [ July 16, 2003: Message edited by: navyblue2000 ]</p>
    SLP CAI, RK Sport headers, P&Ped heads and intake, GT2 cam, Upgraded valvetrain, Z28 rear axle with 4.10s Tx Spd tune, Z06 rims, 2.5\" exhaust to flowmaster, 160* thermo, B&M ripper, upgraded ignition, rockford fosgate 12\" with sony xplode amp and HU.
    Splicing in a new wire should be ok, just as long as its a similar gauge & a short length.
    <a href=\"http://www.cardomain.com/id/sac2165\" target=\"_blank\"> CAMAROS</a>
      For something that touchy and exposed, I would solder the splices and then tape them, but other than that, it should be fine.
      <b>Mike</b><br /><a href=\"http://www.cardomain.com/id/mcjoslyn\" target=\"_blank\">2001 Camaro</a><br />Light Pewter Metallic Convertible<br />AU0,A31,C60,DG7,F41,GU6,K34,L36,M30,T82,T96,UN0<p ><b>If it can\'t be expressed in figures, it is not science; it is opinion.</b>
        I would suggest sodering and shrink wrap to make them water tight and look alot better than tape.
          crimping in some butt-splices would also be good, if you're a not-so-good solderer. be sure to shrink wrap in any case
          --matt
            Hey Fred, where you from in LA. Baton Rouge here.
            2000 Firebird 3.8, auto, flowmaster 80, taillight blackouts, 02 formula swaybars, poly endlinks and energy support bushings, 1 1/2in cut springs
              Yup....id solder too.
              <a href=\"http://www.cardomain.com/id/y87inside\" target=\"_blank\">http://www.cardomain.com/id/y87inside</a>
