Has anyone experienced noises coming from one of the engine pulleys? One of mine makes a lot noise but I can't tell which one. This should be just a simple replacement right? I think it's either one of the two tension pulleys or the compressor pulley. makes almost as much noise as my CAI.
I believe if u take out the belt and just spin the pulleys around you'll hear which one makes the noise. I had a pully go bad on me and that's what i did on it. Easy fix.
3 days ago
