i know on install university there are a few free mods listed, most of them having to do with the area around the maft and such. anyway, are there any free mods for us 6er's to do that consist of parts around the tb--or heck, any parts at all? just wondering, cause it sure would be nice if we get a few hp out of our engines for not much money. thx guys.
free mods
Not much for the 96-97 3.8L V6's. The only one I know about is to remove the air silencer from beside the airbox near the fender. It's a tube with a rectangular cross-section that leads air from the fender wall into the air box.Edward D.<br />1997 Firebird A4 - Black Metallic<br />SLP CAI, Decoma 3\" Catback<br />BMR SFCs, 1LE sway bars<br />some other stuff
I think one free mod consisted of moving your IAT sensor to a remote location on your air assembly where it would be cooler. I have a custom ram air box so i put it closer to the top where the air would read cooler. I heard you can replace a resistor in it too, i think it was a higher resistor so it would send a low voltage reading back to trick it into reading a cooler temp. I heard reports of some malfunctions though. I probably wouldn't recommend it, you would probably see hardly any gains anyway. Of course you can always get rid of dead weight in the car. You can take out your spare tire and jack for starters, every 100lbs is .1 second off your 1/4 time. By the look from your mod list you probably already got most of it already covered for free mods.
I've been researching it here and there.
Some are weight reduction and some are transfer and some are both
Weight reduction:
1) My jack and spare tire came out and a AAA plus card went in its place.
2) front sway bar, bolts and endlinks came off for 12 lbs
3) rear seats both came out plus the rear seat belts
4) front passenger seat has come out before 36 lbs?
5) thing that covers the trunk, gone, 1-2 lbs?
6)empty washer fluid resevoir, hey I do it
7) light weight a arms, 7.5 lbs each
8) light weight k member, 18 lbs
9) manual steering unit, 10.5 lbs
10) fiberglass hood (I'm told amost 30 lbs)
11) front bumper supports (I'm told 30-40 lbs?)
12) rear bumper supports (I'm told 20-30 lbs?)
13) weld drag lites for the front (15 x 3.5 rims with 175 80 tires weighing in at 26 lbs each)
14) 1 piece driveshaft (maybe 5 lbs?)
15) 2 seperate vibration dampening devices, one on torque arm (doughnut shaped) and one on the end of the tranny (just plain funky looking)
Weight transfer:
1) Both my amps and capictor are mounted in the trunk on the wall where you access the rear tail light assemblies.
2) No stb
3) 10 inch sub mounted in thunderform enclosure
I've done all of the above except for the hood and bumper supports.
I've got a weight reduction list from ls1.com
Let me find itThis is from the legend the colonel from ls1.com
Let's go on a diet...
(BTW, I have done nowhere near all of these ideas myself.)
Feel free to make suggestions and to add guesstimations or factual info as to how much weight any of the ideas remove. I'll add that info to the list.
Weight removal list!
First step....
Buy a lightweight optioned car
Free stuff....
....!ABS
21.5!AC compressor
8.5.!AC condenser
....!AC fan motor
15..!Airbags & impact sensors
....!Air dam
1...!Air filter
5...!Amp, Monsoon
4...!Antenna, bracket, and motor if applicable
....!Ashtray & lighter
....!Blinker switch
2...!Bolt lengths, extra
....!Brake pedal pad
23..!Bumper, front reinforcement and brackets
31..!Bumper, rear reinforcement and brackets
40..!Carpet & Sound deadening
50..!Catback
....!Cats
9...!Center console
....!Coating, under carpet
4...!Crossmember brace
....!Cruise control
....!Dash
....!Door panels
11..!EGR, air pump, & harware
....!Emblems
....!Fan, 1
....!Fan shroud
5...!Floormats
3...!Foglights and brackets
....FRA mod
....!Gas, Extra
2.5.!Glovebox
4...!Hatch cover
....!Hatch shocks
....!Headlights
....!Headliner
....!Head unit
....!Head unit/AC console trim piece
....!Hood shocks
1...!Horn
3...!Inner fenderwells, plastic
....!Liscense plate brackets
....!Liscense plate(s)
....!Misc. junk in the car like keys, garage remote, change, owner's manual, etc.
4...!Panels, under steering wheel
....!Parking brake
....!Power brake booster
....!Parking brake handle
....!Power seat motor
....!Power steering pulley and idler pulley
....!Power steering pump
....!Power window motors
1...!Rear view mirror
2...!Seatbelts
34..!Seat, passenger's
19..!Seats, rear
3...!Sheetmetal, extra double walled
....!Shifter knob
5...!Side impact bars
35..!Spare tire and jack
7...!Speaker panels, hatch
5...!Speaker panels, rear passenger's
15..!Speakers
35..!Spoiler (Weight measured on a Pontiac)
....!Spring isolators
2...!Sun visors
14..!Swaybar and brackets, front
....!Taillight(s)
2...!T-Top holders
....!Under car tow points
1...!Washer fluid pump
9...!Windshield washer fluid
2...!Windshield wiper reservoir
3...!Wiper arms
3...!Wiper motor
....!Wiring, Excess
Wallet mods....
....Airlid, aftermarket
....Aluminum LCAs
8...Carbon fiber driveshaft
11..Chromoly A-arms
30..Chromoly K-member
....Draglite wheels
....Drag slicks or street slicks
....Drilled axles
20..Dry cell battery in right rear
18..Electric water pump
....Fiberglass door skins
30..Fiberglass hood
....Fuel cell
....Headers
....Lexan glass
....Lightweight clothing
30..Lightweight brakes
10..Lightweight flywheel
....Lightweight springs and shocks
....Lightweight steering column
....Lightweight steering wheel
....Manual rack and pinion steering
....Plastic fuel tank, late model
....Powerglide, TH350, or M4 transmission
....Racing seat
....Shortbelt mod
....Skinny front tires
....Spool
20..TQ converter, small
....Underdrive pulleys
Is that ok?Race car - gone but not forgotten - 1997 firebird V6
James, I wasn't aware that you had the tubular K-member and control arms. Is this true?- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
<blockquote>quote:</font><hr>Weight transfer:
2) No stb
<hr></blockquote>
ya know james, i'm suprised you haven't taken out the whole freaking stereo system by now. ya take out the amps/sub/speakers/head unit, that's prolly 30-50 lbs, wouldn't you say? that's .05 seconds off your et, and i bet you won't be too happy if you run a 12.04 now would you? ;)2000 NBM M6 Camaro Z28<br />323/335
Back when I was a mustanger, a lot of mustang drivers put their batteries in the trunk of their cars. Its supposed to lighten the load in the engine bay since its easier to pull then push! [img]smile.gif[/img] who knows, but hey it'll cost like what, 10 bucks for the wiring and a little of your time.95 quasar blue 3800.<br />K&N, blackout tint,<br />Headlight and tailight blackouts<br />300 watt 10\'s <br />$400 polk highs and mids<br />pioneer DEH-P6300 HU<br />chrome 5 star 15\" rims
