Camaro (97 3.8 5spd) bogging badly. - FirebirdV6.com/CamaroV6.com Message Board
  • Camaro (97 3.8 5spd) bogging badly.
    So it was having a hard time going stalling and sputtering and then i changed the fuel filter last night and for the night it was driving great only bogged a tiny tiny bit but I gained like 30hp
    This morning it would barely turn over, it tok 20 mins for me to get her going and driving it was ok bogged some more then the night before.
    Afternoon driving home I was sputtering relaly badly didn't matter how much gas, after i get up ot 4k it eased off alot and then it was ok, seemed to get a tiny bit better after 20 mins of driving. but not much.
    What could it be? I'm at a loss.
    a
    You gained 30hp with a fuel filter? How clogged was the old one?
    g
    2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
      Very very very bad, the gas that came out of the filter when I was changing it was dark brown.
      a
        Leaks on the weld of the muffler from the pipe between the cat and the muffler itself.
        Leaking on rear end housing.
        1st and 2nd gear lag all the way at WOT and with everything else.
        3rd gear is really powerful
        4th is so so.
        having a super hard time starting if it sits for a while.
        a
          check your spark plugs, and wires, coils.
          lil_scrappy97@yahoo.com
            sounds like a fuel delivery problem
            hard to start after it sits because the line loses pressure, then it takes awhile to build the pressure back up in the line
            if your fuel filter was that bad, then I have no doubt your fuel pump is in pretty bad shape... im betting the screen sock that acts as a filter for the pump is completely gone by now too
            not to mention your injectors are probably clogged to all hell now
            replace all of your ignition stuff first
            if that doesn't solve the problem move on to the fuel system
            start by following your line from end to end and making sure all is in good order, fixing any trouble spots you find
            after that, consider a fuel pump (it wouldn't hurt to drop your tank if you were getting that much dirt either, i would SERIOUSLY consider it)
            then if you have no change, send your injectors in to cruisin performance to have them cleaned and flow matched, or just get new ones
              What codes are you throwing???
                Gas Backpressure P1441 i think. And I'm having the fuel pump installed, 700$. :(
                a
