Misfire after plug+wire change - FirebirdV6.com/CamaroV6.com Message Board
  • Misfire after plug+wire change
    Alright, I did a plug and wire change on my 96 3.8 After I finnished I ran AutoTap to make sure it was running smoothly. I had a Gauge window open with the Current Misfire #1-#6 so I could see on which cylinder, if any, there was a problem.
    At idle I would get a misfire every 10 seconds or so on one or two cylinders, usually the same ones. I reved it up a bit and got no misfires. I drove around the block, and while accelerating or at a constant speed, I wouldn't get any misfires. But when I idled at stop signs and in the drive way I would get a few misfires. Unfortunatly I did not run AutoTap before hand to get a base reading, always and after thought, so I am wondering if a misfiring at idle, but not under load is normal?
    Let me add a little, all the wires are firm and snug, triple checked. The wires where lightly greased with dielectric grease. The wires have not melted or been visibly damaged. I can not see a spark arcing when under the car.
    The plugs that I put in are Bosch Platnum +4. They have 4 electrodes, and I was told not to gap them. I am wondering if these might be the problem.
    [ June 14, 2002: Message edited by: BillyCobin ]</p>
    <a href=\"http://www.fatninjas.com/camaro\" target=\"_blank\">\'96 Camaro Convertible</a>
    misifre at all is not normal. I once didn't put a plug all the way on snug and it gave me a misfire here and there.
    <b>99\' Black Camaro SS</b> <br />M6/T-Tops - SLPLid w/K&N | Hurst Billet Plus w/ LSS | EGR Mod<p>Black 97\' Camaro T-Tops (RIP)
      If you don't get the plug in tight the first time you fire up, the coil might be damaged.
      I would check that all the plugs are tight, and I would get rid of those Bosch plugs.
      I've had three different kinds of Bosch plugs (including the Platinum +4's) in my car and none of them ran as good as the AC Delco that were in it before.
      I have a 95 3.4L, so I didn't get any misfire codes or antyhing, but it would miss once every few seconds on random cylinders. Changed the plugs to AC and problem fixed.
      I have no idea why this is the case, but it is in my case.
      Good luck.
      -Brian
      Maroon 1995 Camaro<br />No mods yet...<br />Lucky to have found this site!
        I recently had a misfire situation with the SES light flashing. Had the dealer check and they replaced a bad plug wire (free under their campaign). One week later, got another SES light but steady this time. Took to autozone (free scan check) and they showed a cylinder misfire. Cleared the code and have had no more problems. I gotta believe that GM has a major problem here but is too cheap to own up to it.
