ok guys, got my codes from the computer... - FirebirdV6.com/CamaroV6.com Message Board
  • ok guys, got my codes from the computer...
    PO305...Cylinder 5 Misfire Detected
    the guy at autozone said i should get a full tune up, replace all the spark plugs and such
    the car has been idling rough and if i really punch the acceleration, the engine just shuts off
    think this will solve the problem?
    thanks
    mcG<br />aim=endlive<br /><a href=\"http://www.cardomain.com/id/endlive\" target=\"_blank\">97 firebird</a> ~ wrecked
    Sounds like Plugs/Wires to me!
    Should fix your problem!
      yep.. if you have never done them before set aside about 3 hrs or so to do them.. unless of course you have headers.. don't get in a hurry.. when you put everythiing back together be careful with the routing of your wires, (a drop light helps with this also)
      of course do a visual inspection first because it could just be a loose wire... last time I had a cylinder 5 misfire it was my coil.. though if your plugs and wires have never been done I'd bet that's the problem
      -Brad
      2000 V-Star Custom 1100
      :rock:
