K, well I think I need to change my fuel filter, and at www.installuniversity.com the tutorial shows them purging gas out of the fuel injector lines or whatever, u remove a small cap and press on a buton like mechanism and gas comes out, question is, where is that crap on a V6? I cant find it, and where in the bottom is the filter?
Fuel Filter change on a 2000 Bird
It's on top of the engine, should have a little green cap on it. Just get a rag and put it over top of the valve then push it in with a screwdriver or something.2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
its easier than that. open the fuel tank cap for like a few momments. put it back on. get under there and quickly unscrew it and put the new one on. a little gas will come out but for the most part it will be a slow drip. have plenty of rags handy. took me 5 mins. n o need to do that green gizmo thing. atleast i didnt.Heady Navy Blue Metalic<br />Heady Catback Flowmasters<br />Heady Bilstien HDs, PAnhard rod, LCAs,SFCs<br />NGK\'s and MSD Wires, K&N flowin + Smooth Bellow<br />Y87 3800 GT Performance.<br />I love the way this car makes turns!<br /><br />1989 black Camoaro RS. R.I.P.
unscrew gas cap...leave off. Purge fuel rail at scrader port...paseenger side fuel rail...towards front of engine...little black cap. (the green cap vent works as well...manuals recomend the fuel rail shrader valve though)
fuel filter is under car. follow fuel lines...you will see it.
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...4 weeks ago
