Cam Install Guide By Slacker69 - FirebirdV6.com/CamaroV6.com Message Board
  • Cam Install Guide By Slacker69
    I have done 2 cam installes on a 3.8L camaro
    1.you have to move the fans off the radiator can stay.
    2.You have to take off the altenator and TB and coil packs first
    3.then I would get the crank pully bolt off. I use a long breaker bar and then slid the jack handle over the breaker bar to make it even longer. Then get a friend to jam a screw driver between the flywheel and the tranny housing to lock up the motor. You have to take off the starter to get to a good spot. This bolt is tough so dont get pissed.
    4.Then take off the map sensor it is two torx bits.
    5.Then you will want to take off the upper intake then the lower intake.
    6.Then take off the valve covers.
    7.If you are not doing heads then you are now ready to take off the crank pully whice you use a pully puller.
    8.Then you will want to take off the front cover pretty easy. But when you take it off try not to turn the gear thing in the hole where the crank goes through. If you do it is a pain to get lined back up when it is time to assemble.
    9.Then take off the timing dampener one bolt no problem. Good idea to replace this part for proper timing.
    10.Then take off the cam sproket bolt. now you can take the cam gears and crank gears off. dont loose the little tab on the cam.
    11.Now you will want to pull the pushrods and lifters out make sure when you put it back together to use new rocker bolts.
    12.Now pull out the cam best to put the bolt back into the cam so you have something to hold onto. slide out carefully dont bang up any of the bearings. once it is out you can do whatever with it but i would keep it clean and unbanged up just incase you have to put it back in later.
    13.Now you can put the new cam in pour alot of heavy oil on it. once again dont bang up the bearings slid it in as smooth as possible.
    14.once it u need to start putting the cam gears and crank sprocket. make sure the dots line up on all the gears if they dont you will have messed up timing and could mess up your car. So pay close attention to this
    15.make sure there is the cam magnet in the cam gear it looks like a little black button.
    16.Now begine to re put back all componets in the reverse order that you took them off. Make sure you do all your TQ specs right esspecially the heads(if you do them) The cam gear, and the rockers arms.
    17.double check everything make sure all your fluids are full like your radiator and oil and everything
    18.make sure all your sensors are on and all the vac lines are hooked up
    19.time to start it up and have fun. Be easy on it for around the first 500-1000 miles.
    Guide by Kris Thomas
    a.k.a Slacker69
    More info and pics can be found here also.
    http://www.dxsoftware.com/magnus/v6headscam.htm
    [ October 25, 2003: Message edited by: slacker69 ]</p>
    <b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport Headers
    Thought it would be more popular
      I enjoyed reading it [img]smile.gif[/img] Thanks for posting good information.
      00\' firebird v6 5spd<br />201rwhp ---- 230 rwtq<br />\"Everyday I grow stronger...and further from you.\"<br />WARNING: Do not take any of my comments seriously unless they are technical in nature and then only at your own risk
        bookmarked. ;)
        Silver \'98 Camaro M5<br />Current MODs:<br />SLP strut tower brace; SLP 1LE swaybars front/back; Powerslot rotors; Hawk pads; Eibach springs; Bilstein SLP shock kit; SLP trans mount; Zexel limited-slip differential; LS1 drive shaft.<br />Possible future MODs:<br />BMR Lower Control Arms; BMR Pandhard Rod.
          awesome, i always wondered what was involved. now i'm thinking i could do the install myself instead of paying someone way too much to do it.
          2000 pewter firebird<br />Short Throw Shifter, Whisper Lid, Whisper Ram Air, Holley Filter, B&B Triflo, LSD, BMR LCA, STB, PHR, and sway bars (32/21).<br />Power window conversion
            Isn't there a specified breakin time for the cam you installed. Mine for example, was 10mins@2000rpm and then shut down and do it over again twice.
            Just wondering, this is important if you don't want to shave off any of those lobes.
              no cause it is a hydrolic roller setup but i did a part breakin I helled 2500 rpms for 10 mins and then shut it off let it cool down then started it up and let it warm up and held 3500 rpms for 10 mins even though you dont need it
                Can you use that guide for a cam install on a 3.4L????
                Ben<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
                  Sweet.. [img]graemlins/thumbsup.gif[/img]
                  2000 Firebird. Whisper Lid, True duals, TSP mail order tune, Built Tranny , TCI 2800 stall verter, B&M tranny cooler, Eaton LSD, 3.42 gears. Current best ET. 15.232 89.09 MPH 2.175 60ft on stock 3.42\'s and open diff.<a href=\"http://www.geocities.c
                    That is the basic pricaples of any cam install but some of the details about the sensors and what not might differ
                      you gave me an idea of what needs to be done. although i will probably seek help from some volunteer near MD,
                      knowledge is power and you my friend have made me even stronger.......... [img]graemlins/thumbsup.gif[/img]
                      - \"So you have something to look at when you\'re talking to \'em\" - <br /> <a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=296916\" target=\"_blank\">http://www.cardomain.com/member_pages/view_page.pl?page_id=296916</a>
                        awesome, thanks kris, hey if/when i get a cam, i'll buy the beer/pizza, if you'll help with the install? we'll make it a SICK-SIXX gtg for real this time...
                        merlin
                        2002 Firebird<br />2003 Yamaha YZF 600R
