just bought a 95 camaro for my dirving back and fourth car. It seems that one of the pullies is squelling and the ac doesn't get real cold. could the ac be goin out. also the abs INOP light is staying on. what is the problem. :mad:
3.4 camaro problems
the pullys could be the bearing in the tensoner pully going out
donno about the ac
and the abs inop light is on because your 3rd brake light is burnt outWolf<br /><a href=\"http://www.cardomain.com/memberpage/249111/7\" target=\"_blank\">95 black t-top camaro</a>,3.4 5 speed,ud pullies,plugs/wires,de-shaft tb & gutted airbox, homemaid short throw shifter
thanks wolf for the info but by any chance do you know the cost of the bearing for the tensoner pully cost and how hard is it to install? Also if you don't mind me asking how did you know that it is the third brake light that is out because in my owners manual it said not to drive the car with the light on but it didn't say anything about it just being the third brake light being out.
You will have to get the tensioner assymbly, don't know how mugh, but easy to get to & replace. For the low output a/c, you cain go to a parts store, get a gauge & refill. for full service, take it to a qualified mechanic.1978 Formula 461 in progress of being built :rock:
2013 Ram 1500 Big Horn
94 comero 3.4
<blockquote>quote:</font><hr>Originally posted by 98v6bird:
Also if you don't mind me asking how did you know that it is the third brake light that is out because in my owners manual it said not to drive the car with the light on but it didn't say anything about it just being the third brake light being out.<hr></blockquote>
a friends camaro had the abs inop light come on when his 3rd brake light burnt outWolf<br /><a href=\"http://www.cardomain.com/memberpage/249111/7\" target=\"_blank\">95 black t-top camaro</a>,3.4 5 speed,ud pullies,plugs/wires,de-shaft tb & gutted airbox, homemaid short throw shifter
Also another thought about the ABS INOP it pops on everytime your car charges low. Just a thought if oyur belt is not turning the compressor it won't work well and if the belt ain't turning the alternator it won't charge well thus throwing the ABS INOP light(safety feature to give the car more power then to jsut die on you)
PErsonally I woudl assume a belt issue before oyu tried recharging your AC and changing brake lights. Seems to things leading to the belt not spinning things right then something off the wall like the 3rd brake light, which will set off the light, but my car is a 94 with 128,000 miles on it and I have the stock 3rd brake light(*knock on wood*)
And if the tensionor is not creating tensions on the belt, it may only be half turning the accessories, notice any problems with the powe steering or enigne temps?
[ August 03, 2003: Message edited by: MustangEater8251 ]</p>
I also had teh ABS light stay on in my Blazer. There was a lead fromt he POS battery cable that went to the ABS computer. It has corroded thru. Check & see if your battery cable also has this. I was able to cut & splice to fix problem.1978 Formula 461 in progress of being built :rock:
94 comero 3.4
tensioner is $37 at O'Reilly's, Just got one Friday.Joel<br />God is my copilot, but Satan has his foot on the gas!<br />94 3.4L AutoCamaroRagtop w/MSD ignition,Accelcoilpacks,K&N FIPK,BMR SFC&STB,3\"Catco w/3\"catbackSS muffler,JetStage 2,HomemadePIAAheadlightconversion <a href=\"http://www.geocities.com/cardiac1968\" target=\"_blank\">http://www.geocities.com/cardiac1968</a>
<blockquote>quote:</font><hr>Originally posted by 3.4 slow to go:
I also had teh ABS light stay on in my Blazer. There was a lead fromt he POS battery cable that went to the ABS computer. It has corroded thru. Check & see if your battery cable also has this. I was able to cut & splice to fix problem.<hr></blockquote>
What year was your Blazer, I had headaches and headaches of brake problems on a 92 GMC Jimmy I had between my 85 camaro and my 94 Camaro.
Just a thought, maybe the ABS system is malfunctioning and the light has been thrown. The manual is right, don't drive the car until you find the root of the problem, it can cause serious damage to the ABS system.
As for the AC...is the compressor making any noise? Loud scraping or squealing? It could be low on R134A, but if it just spins and never engages, it could be a bad compressor or pump...or just out of 134A. A major leak will be obvious, there will be an oily deposit near a fitting on the system, but not all leaks can be seen. You can add dye, or use a refrigerant detector. Any shop can do these things.Teal 94 Camaro 3.4 Liter<br />Transgo stage 3 shiftkit, Shift module, corvette servo, SLP cold air induction,3.42 ring and pinion, Heavy Duty Posi LSD, Flowmaster exhaust, NX, blackouts
