Well im pretty sure i have a head blown gasket. It leaks anti-freeze a lil bit and leaves drops under neath the car after it has run for awhile. Takes about a month for the radiator to completly empty(which i dont let happen). Yes it is coming from the head gasket.
Oil is fine, nice and clean. Car runs perfect with no funny sounds. It just leaks a lil anti-freeze everytime the car is run.
Dont have the money to replace the headgasket now so what are the best products that help to stop it?
1994 firebird red t-tops 115K miles. needs paint job badly<br /><br />1993 camaro - gone<br /><br />1995 camaro - rdy to be drivin :)<br /><br />1987 camaro - slow *** v8 - blew it up ha
You sure it's not just a bad water pump? If it is indeed a BHG, I'd also suggest getting your heads checked over from cracks. I cracked a head with 85,XXX and my car was like yours, ran fine and leaked a little antifreeze.
Its deff not the water pump. The anti freeze leaks between the water pump and below the thermostat. Trickles down the lil groove between the braket which u need a flashlight to see.
No hoses leak
Water pump is fine
Trickles down between the grove between the braket where the waterpump/thermostat sits
Car runs like its new
Oil is clean
Smokes a tad but its hardly noticible
