whenever i am accelerating my car stutters and jerks around and the check engine light comes on and it loses lots of power, like it feels like a 110 horsepower car for example, but then when i shift into another gear it is ok untill i try to accelerate. has anyone else had this problem, does anyone know what i can do?
Sounds like what i went through with my Firebird. If you have an Autozone nearby stop there and have them test your car. If you get a code that says misfire in any cylinder, it would be your plug wires. After reading alot about my car it seems that these F bodies are kinda notorious for having plug wires go bad with a little help from the exhaust manifold. They may appear to be in good shape, as mine did. But theres only 1 way to really find out.
1996 Arctic White Firebird , Auto , stock <a href=\"http://www.cardomain.com/id/smokeyinswf\" target=\"_blank\">http://www.cardomain.com/id/smokeyinswf</a>
The SES light flashes when you have multiple misfires. I was lucky when it happened to me. I was just dumb and didnt plug in one of my plugs all the way. [img]graemlins/slap.gif[/img]
1999 Grand Prix GT<br /><br /><a href=\"http://www.fishsgt.com\" target=\"_blank\">www.fishsgt.com</a><br /><br />Best ET: 14.94@91.25MPH with a 2.2 60\"
i had the SAME EXACT problem on my old camaro and my cat was clogged... i went out and bought a new exhaust system (cat back + new cat) and didn't have a hint of the same problem again!!
