Hey everyone,
I remember hearing that you can put in an oil filter that is made for a 4.3L engine such as a Blazer and put it into a Camaro. This true?
Why would you want to do this? I am curious. It doesn't up your horsepower any, and if you are setting the system up for racing, there are several oil filter adapters out on the market that let you run just about anything you want.
Using oversize oil filters on 3.8L is common. Two oversize oil filters for the 3.8L are: AC Delco PF52 and Purolator PL24011. There are many others. Don't know the K&N number.
I like the Purolator.
[ August 17, 2003: Message edited by: Red2K1 ]
[ August 17, 2003: Message edited by: Red2K1 ]</p>
2001 Camaro M5 Coupe(1 of 2,737), no options, Whisper Lid, K&N Air Filter, Free Ram Air, MAFS Screen removed, SLP Manual Fan Switch, 160 thermo, DEE\'s T/B Spacer, EGR Block-off plate, IAT resistor, CAI to EGR air feed, B&M Ripper Shifter, SLP Replacement Grill, T/A Exhaust, SLP five spoke take-off wheels, BMR strut-tower brace, BMR Tunnel Brace, BMR 32/21 front & rear sway bars with poly, BMR Poly/Combo Rear Control Arms, Clear front & rear corners, HPP3 modified 87 Octane program.<p><a href=\"http://www.cardomain.com/id/red2k1\" target=\"_blank\">http://www.cardomain.com/id/red2k1</a>
regular and routine maintainance is the biggest deciding factor to engine longevity.
The engine with the top of the line oils and filters changed at 10,000 miles. Will live a short life compared to the engine that uses the cheapest no-name brands changed at 3,000 miles.
<b>15.41</b> @ 89.80 & 15.45 @ <b>91.64</b>, 2.21 60ft, 3,440 raceweight, using <b>OEM</b> Equipment. <br />\'98 L67/M49 w/ 134,000 miles before spun bearing. \"<i>It\'s all stock, Baby</i>!\"
