I'm trying to remove the fuel injectors from a fuel rail for a 98 Camaro with a 3.8 V-6 engine. The fuel rail has been removed completely from the engine. I removed the retainer clip, and tried pulling on the injector with a lot of force with a twisting motion and the fuel injector won't break free. Any suggestions or tips on removing these injectors?
Fuel Injector Replacement
Re: Fuel Injector Replacement
it's a pita trying to remove these injectors. they are located in a tight spot also. Remove the retaining pin first and then start twisting and wiggling it to try to get to loosen up then give it all you got pull the fuel injector out. if it's still tight wiggle it again and pull it out. Hope this helps to those who encounter the same problem.
