The output shaft seal or rear tranny seal (whatever its called) appears to be leaking a little. How much does it usually cost to have these replaced. Thanks
output shaft seal?
so should I be expecting no more than $50 to get this replaced? I just want to get an estimated figure so the shop doesnt try to rip me off.1995 3.4L M5 Camaro<br />Bullet Performance Exhaust, K&N FIPK, Stage 1 clutch, Short shifter, Hotchkis STB, Taylor Ignition wires, NGK spark plugs
Had to replace mine last summer. Spend like $3 bucks from GM for the seal. Local tranny shop swapped it out for $35 bucks. Only took them like 20 minutes. No problems since.1995 Camaro 3.4L A4<br />Check out my other ride. <a href=\"http://www.sounddomain.com/ride/820732\" target=\"_blank\">www.sounddomain.com/ride/820732</a>
Mines doing the same thing too and I'm about to replace it myself. Is there like a special tool I need to use to take the old one out?1997 Camaro Y87. Turbo.<br /><a href=\"http://pureoctaneracing.net/\" target=\"_blank\">Pure Octane Racing</a>
Originally posted by ChronoGN:
Mines doing the same thing too and I'm about to replace it myself. Is there like a special tool I need to use to take the old one out?- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
