a/c delete - FirebirdV6.com/CamaroV6.com Message Board
a/c delete
  • a/c delete
    i want to do a a/c delete but how can i do it? is there a special pully to put in its place so when u take at the a/c? or do i rerout the belt? let me thanks
    2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
    go to advance auto and by a 62" 6 ribbed belt for like 16 bucks. starting at the alternator, go to the power steering pump, the to the crank, then around the water pump anback to the alternator. if you want to take the a/c components off, you can but definately dont have to. that way, if you need it, you can just switch the belt back.
    96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHR
      Yeah what timmy said. I did this on my old firebird because the A/C unit locked up, being winter didn't feel like putting a new AC compressor on at the time, ran it without it going to the compressor. Summer rolled around bought a new A/C compressor, next week the car got totalled. But yeah I noticed you live in Riverside, Cali. I figure it gets kinda hot there in middle of summer.
        Will that same belt work for the 3.4?
        All black 94 3.4L Camaro <br />5 speed with t-tops<br />Mods-<br />Cold air intake, Duels no cat<br />Iroc rims, Manual fan switch
          Yea, what they asked, will that work on the 3.4???
            My old car was a 3.4 but unsure of what belt I used, sorry.
              610k6 I have this belt on my engine. It takes a hammer & flathead screwdriver to put this ***** on, but teh next size up was too loose.
              routing
              belt was about $16, a lot less than the dead pulley from teh next post vvv
              for teh 3.4, THIS
              configuration i had used a 685k6
              [ March 20, 2005, 01:40 AM: Message edited by: 3.4 slow to go ]
              2013 Ram 1500 Big Horn
              94 comero 3.4
                If you intend to remove the compressor you can replace it with a dead pulley from Intense for around $100 and keep the stock belt...the ac junk weighs around 28 pounds so it depends how much you think it is worth it.
                  GM sells a pulley for the 3.4 that can be used if you remove the AC compressor. It will bolt to the accessory bracket and allow you to use the stock belt routing and makes better contact with the tensioner pulley.
                    where could i get a dead pulley
                      Dealership.
                        gmpartsdirect.com
                          10115875 is the GM Part number.
                            i havnt had any problems with my belt slipping without a dead pulley
                            -Aaron, AKA ATL2001<br />93 3.4L <br /><a href=\"http://www.ilfba.com\" target=\"_blank\">www.ilfba.com</a>
                              I didn't really have any serious issues but felt more comfortable with the idler pulley.
