Turn Signals do not work... - FirebirdV6.com/CamaroV6.com Message Board
  • Turn Signals do not work...
    I searched the database here and could not find anyone with the exact problem i am having...
    In my 99 Firebird when i turn on the turn signals the indicator just stays solid to whatever direction i point it to. When I turn on the signals the turn signals will light up in the back, and are solid, but i do not see any life in the front. Is it possible both front signals are burnt out? could it be a fuse or relay somewhere?
    If it helps, I have a fog lamp out, could that be related?
    [ November 24, 2002: Message edited by: Clayton ]</p>
    Clayton - White 99 Firechicken<br />*********************************
    Its the blinker relay - just buy some new ones. If its like my old 66 Chevy truck was it has one one for each side...
    2002 5-spd NBM Camaro
    Details: www.1lev6.com
      If the relay isn't the problem, check your bulbs. I had a signal bulb (one of the 2-way bulbs) in the taillight go out on my '94, and the blinker did exactly as you have described (the side with the blown bulb was the side that didn't work).
      2001 Onyx Black Camaro M5-Totalled<br />2005 Ford F150 XLT 5.4L<br /><br />\"To make peace, prepare for war.\"
        Something occured to me when a Camaro passed me on my lunch break. My day time running lights are never on... Those also function as turn signal's don't they? If I am thinking correctly then they are the problem. What are the odds of both bulbs being blown? Think it could be a fuse instead?
          Check the fuses....do your taillights work?
            tail lights work fine. on a side note - i am missing the fuse box covers, so i do not have a diagram i can go by - is there a diagram anywhere online that would tell me what fuses to look at?
            I agree with you on the fuse idea, because the turn indicators on the front bumper also do not seem to work. It would be an odd coincidence to have four lights out...
              they blinker usually doesn't work if your bulbs are bad,thats what happened to me
                http://www.thenebula.com/carpics/pics/fuse.JPG
                its also in the manual ;)
                2002 Black FireBird M5 2-5-02<br />Red BMR strut bar<br />Dynomax Super Turbo muffler with FastToys.com tips.<br />4 Coats of Zaino - Better every time<p>Need to post pictures? Do it <a href=\"http://www.thenebula.com/carpics/\" target=\"_blank\">here</a>. its <b>easy</b> and <b>free</b>.<br />Change your own oil. <a href=\"http://www.thenebula.com/firebird/oil/\" target=\"_blank\">click here</a>.
                  its yout bulbs get new ones.....4$
                  05' CTS-V
                  00' Camaro - SOLD :(
                    If a turn signal buls is loose it will cause the blonker to just stay lit and not flash. Chect the bulbs to see a tight fit and they arn not burned out.
                    1999 Camaro V6 A4<br />Navy Blue metallic<br />Intake+Exhaust+4.10+?=?
                      thanks for the fuse layout. I really need to buy myself an owners manual.
                        http://www.thenebula.com/firebird/2002firebird.pdf
                        Heres the manual for my car. You can download it off of pontiac.com
