Is it just mine, or are your fog lights full of water? One is totaly full and the other is half full..... they both turn on and work fine... which doesnt make any sence??
Water in Fog lights. 94 camaro?????
mine don't have water in them. Thats weird that they still work fine though.
I wonder if its actually in the case w/ the bulb; or is there a casing it could be in (outside the bulb case but inside the plastic- if that makes sense). I haven't looked at mine in a while.
-Justin2001 Camaro Z28 (A4) Sunset Orange Metallic w/ T-tops, Monsoon Stereo, factory GFX, BMR STB from the v6, 18K miles<br /><a href=\"http://www.cardomain.com/id/jhkcam22\" target=\"_blank\">2001 Camaro Z28</a><br /><br />Dads car: 2002 35th aniv. Bright red Z28, fully loaded<br /><br />R.I.P.<br />1995 3.4L Camaro (A4) Bright Red<br /><a href=\"http://www.cardomain.com/id/jhkcam\" target=\"_blank\">1995 3.4 Camaro</a>
im guessing youre talking about the headlight housing and not the bulb itself?
Just get some clear silicone and re-seal them94 Quasar Blue Z28<br /><a href=\"http://www.9t4z28.com\" target=\"_blank\">http://www.9t4z28.com</a><br /><a href=\"http://www.9t4z28.com/Dyno1.htm\" target=\"_blank\">http://www.9t4z28.com/Dyno1.htm</a>
