If your coil pack is going bad or not work at its best. I am loosing power somewere and have no clue what it could be.
how do you tell
i would do a all around tune up plugs plug wires coils change fluids couldn't hurt1998 Jet Black Trans-am M6 T-tops<br />\"Ask, and it shall be given you; seek, and ye shall find: knock and it shall be opened unto you:-Matthew 7:7<br />Old car<br /><a href=\"http://matthew27529.tripod.com/getsome\" target=\"_blank\">http://matthew27529.tripod.com/getsome</a><br />NEW CAR<br /><a href=\"http://garnerebel.tripod.com/\" target=\"_blank\">http://garnerebel.tripod.com/</a>
the best way to narrow a probelm to a coil is... if you are getting an SES light then scan the code check the cylinder.. clear the codes.. swap coils around.. run the car again till you get an SES.. see if the misfire has moved.. if it moved with the coil.. then the problem is the coil.. that's the best way I know how..-Brad
2000 V-Star Custom 1100
:rock:
