car wont start - FirebirdV6.com/CamaroV6.com Message Board
car wont start
  • car wont start
    friday morning i got in my car and it was having trouble starting. i would turn it on, and about 2 seconds later it would just die. after 7 times, it started fine and ran great all day. last night, i was going to go to a friends house and i was having the same problem. except it never started. after the 20th time it started to sound a little violent so i called it a day and gave up. i think its becuase the car is cold, its done it a few times but it always ends up starting. i cant wait until i get rid of this pile. i think it might have something to do with the engine not getting enough air, but im no expert. any ideas?
    When was the last time the air and fuel filters were changed?
      no idea
      is it something i could do myself?
        air filters are real easy. fuel filters are a little harder http://www.installuniversity.com/ins...sity/index.htm hope that helps
          my car did that too... it would take a few trys to get it started and it would run rough for a few minutes.. but after that it was perfect.. until next time u go to start it.. it was fuel pressure regulator
          1999 Black Pontiac Firebird <br />2 Rockford Fosgate P312D4 subs <br />Hifonics Brutus 1205d amp<br />Clear Sidemarkers<br />18\" Arelli Jovan Chrome Wheels
            was that easy to fix?
              maybe a bad starter?
                if it was the starter, wouldn't it just not start at all? what happens is that the car starts fine then after a few seconds it dies. I've tried revving the engine and even throwing it in drive, trying to keep it from dying (I've done both of those before and it stopped it from dying). But alas, no luck.
                also, bret you mentioned fuel pressure regulator. if the fuel pressure was really low, i.e. schraeder valve or fel cap was off, would this happen?
                  it doesnt make the fuel pressure low really... mine was normal... it just regulates the fuel it gets when u start.. at least i think thats what it does since it was fine after a few minutes... you said that revving it up kept it from dying? thats exactly how mine was.. i'm about 95% sure its the fuel pressure regulator.. its about a 30$ part.. i dont know how hard it is to do yourself.. i let a shop do it cause i was busy with summer ball... hope that helps
                    well the revving doesnt work anymore, and i only had to do it a few times and that was a month ago. i'll look into it, although im not too worried becuase im going to get rid of it soon.
                      it might just be getting too bad for that to help... i dont know.. but on my way to figure out this problem i replaced all my injectors and fuel rail.... $600+ :( it was no good at all...
