I'm looking for the block drain plug and the radiator drain plug. I THOUGHT it would be obviouse but I can't find it... If anyone can post pic's that would be GREAT but description would do...
Where are the Coolant Drain Plugs on the 3.8's?...
There should be a drain **** on the passenger side of the radiator, on the bottom. If you look from underneath, you will see a hole in the support the radiator rests on that it sticks through.
lol, forgot it blocks ****, no matter the context. Where the ****'s are, just put in the word valve instead.1997 Cayenne Red Metallic Camaro<br />3.8 V6 M5<br />SLP Cold Air Intake<br />Ceramic Coated Pacesetter Headers <br />Flowmaster American Thunder Catback<br />Full 3.42 & Disc Break Rear End Swap
So is it that thing that looks like it has a screw on cap on the underside of the radiator on the passenger side? It LOOKS like it has a thin piece sticking out from it's end and you can turn that piece to unscrew it like it was a cork. Is this it or am I looking more so for a bolt?...1997 Camaro RS W/T-Tops<br />All Stock / 200 HP
