ECU/PCM HELP!!!!!!!! - FirebirdV6.com/CamaroV6.com Message Board
  • ECU/PCM HELP!!!!!!!!
    look at the i con, im F'ED. so this is what happed my computer craped out, a new one from gm is like 2000$, on i cant find any 1997 from junk yard is a 1998 or 2000 and up, i would like the 2001 cause then i could get PROGRAMMING will it work, please need help fast!!!!!!!!!!!!!!!!!!!!!!
    www.turbov6camaro.com
    1997 3800 Series II Camaro
    You need the PCM from a 96-97 and it needs to be programmed for you car...most GM dealerships can flash it for less than $100.
      a 96 or 97 will work but get one for a 97 with the same gear as you, 3.08 or 3.42 and same transmission and just slap it in.
      also, this is really basic so I'm moving it to general.
        <blockquote>quote:</font><hr>Originally posted by viper04af:
        look at the i con, im F'ED. so this is what happed my computer craped out, a new one from gm is like 2000$, on i cant find any 1997 from junk yard is a 1998 or 2000 and up, i would like the 2001 cause then i could get PROGRAMMING will it work, please need help fast!!!!!!!!!!!!!!!!!!!!!! <hr></blockquote>
        I have one for a 97 3.8, but it's a non-y87.
        If you are interested, email me.
        -Marc
