Hey guys. Ive come across a problem with my 3rd gen 1990 firebird 3.1. Every once and a while my car stalled out when i put it in drive or reverse and ive had to restart it. This is at normal driving temperature. But recently it shut off one night while driving. It came to a rolling stop, and i got to restart it. But now its not even starting. At first i though electrical, but now i think fuel. I just wanted to know if anyone else has experinced this problem. Thank You
Car is Shutting Off While Driving!!
Replace your fuel filter if you haven't done so in awhile.1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
Dude. i had the same problem with my 89er. Check for spark. your ignition coil could be going out. mine did the same exact thing. Check your distributor compents, and plugs. definalty check ur sparks .Heady Navy Blue Metalic<br />Heady Catback Flowmasters<br />Heady Bilstien HDs, PAnhard rod, LCAs,SFCs<br />NGK\'s and MSD Wires, K&N flowin + Smooth Bellow<br />Y87 3800 GT Performance.<br />I love the way this car makes turns!<br /><br />1989 black Camoaro RS. R.I.P.
If fuel and spark are good, it's probably MAF, causes a lean condition and stalling. Will usually throw a code 44. Have you gotten any SES lights? If so, done the paper clip trick to read the code?1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
Seems you have an intermittent battery connection which will also cause this shut-off condition. A vehicle in motion with a loose connection will play games with your head.
Recheck, tighten terminals & clean any signs of corrosion.
Happened to me while I was driving my '91. I hope that's your problem.Black \'96 RS Camaro, 3.8 V6 Series II, M5, Stock 200 HP, 204K miles! Stock \'91 Firebird 3.1 V6 automatic w/ overdrive. 266,400 miles on it. \'83 Pontiac Trans Am,305 LG4, Cowl Induction,Borg Warner 5 Speed,T-Tops,Gale Banks Exhaust System:$800 obo
also when checking battery terminals check ur ground connection. it mihgt have wiggled its way loose'99 Camaro Y87 M5 T-tops
Flowmaster american thunder cat back, 2.5" magnaflow high flow cat, centerforce dual friction clutch
Car Domain
