So I went out and bought fog lights and I bought the factory switch that came with the camaros. My question is where are the wires that the switch connectes to run? Did they run these wires even though I do not have foglights from the factory? If not can these be accessed or do I have to run my own wires to this switch? Any help would be great.
Fog Light hook-up
I can tell you how it is set up in my 2001. The wires are run from the fuse block under the hood to the inside of the car. They terminate in the center of the dash board with a factory connector to hook up to the switch. If you remove the center radio surround bezel you will find the wires with the connector. What is not pre-wired, at least in mine, is from the under hood fuse box to the the fog lights.2001 Camaro M5 Coupe(1 of 2,737), no options, Whisper Lid, K&N Air Filter, Free Ram Air, MAFS Screen removed, SLP Manual Fan Switch, 160 thermo, DEE\'s T/B Spacer, EGR Block-off plate, IAT resistor, CAI to EGR air feed, B&M Ripper Shifter, SLP Replacement Grill, T/A Exhaust, SLP five spoke take-off wheels, BMR strut-tower brace, BMR Tunnel Brace, BMR 32/21 front & rear sway bars with poly, BMR Poly/Combo Rear Control Arms, Clear front & rear corners, HPP3 modified 87 Octane program.<p><a href=\"http://www.cardomain.com/id/red2k1\" target=\"_blank\">http://www.cardomain.com/id/red2k1</a>
