2nd gear syncro question - FirebirdV6.com/CamaroV6.com Message Board
  • 2nd gear syncro question
    everytime i shift into second gear it grinds..
    could it be that my clutch has a bad throwout bearing? or could it be a bad syncro.
    when im driving normally in city traffic it doesnt grind. but when im racing or whatever.. and shift from 1st to second at about 5700 rpms, no matter how much i press down the clutch it still grinds.
    if its a syncro, how much would this cost?
    [ March 08, 2004, 01:31 AM: Message edited by: Tyler ]
    96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view&current=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
    YOu beat that 1-2 shift kind of hard?
    If its a synchro, you are looking at pretty much a rebuild... $700-$1100?
    Oddly enough twice when I blew out my 2nd gear synchro I was fine racing it but driving normal, it woudl grind and kick me out, then eventually jsut not let me in at all...
    BTw drivetrain might have better answers then here.
      thats why im HOPEING its just the throw out bearing or something??? i dunno. normal driving conditions its fine. but it never throws me out of gear.
      i guess and wait till i get the spec 3 put in.. should be a week or two
        Are you doing the cluth yourself or having a place do it?
        Might want to consider a used T5, and clutch install all at once... save a little money...
        To be honest... I hoped for something simple, but it most likely woudl be affecting you in other gears...
        If oyu raced or drive hard(I assumed you did if putting in a spec stage II) you most likely damaged something that needs to be rebuilt or replaced. 1-2 shift is usually the hardest. And what went out on me first on my trannies...
        Well once when the 2n gear synchro was going bad, the 3rd gear one took a dump, and then I couldn't use 1st, 3rd, or 5th gear... that sucked... Had to drive 2,then 4. [img]smile.gif[/img]
          btw as a heads up someone is selling a 5-speed out of a 98 in the for sale section with 48,000 miles on it...
            well my uncle is a master mechanic.. he can do anything. he rebuilds tranny's also.. he is doing my clutch.
            ya my 1 to 2 shift is harsh on the tranny. even my 2 to 3 is pretty harsh.
            im putting a stage 3 in because i know sooner or later i will be getting a turbo kit for this car.. and i just want it to be prepared.
              It's your syncro
              I had to replace my tranny at 120k miles
              used tranny cost me about $500
              ~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
                But i only have 61k miles! [img]graemlins/rant.gif[/img] :crybaby:
                  Its driving habits...
                  i had to replace a clutch, flywheel, pressureplate, and master &slave cylinder at 7,000 miles...
                  I went through 2 rebuilds in 6 months...
                    we are just too hardcore for teh borg warner [img]graemlins/naughty.gif[/img]
